December 31, 2025, 10:55:17 AM *
Author Topic: Are all fan switches the same?  (Read 1001 times)
mauigts
Maui, HI
« on: August 12, 2019, 06:38:53 PM »
I own 2 valks, 97, and a 99. I am just wondering if the fan (thermo) switches are all the same, as in turning on the fan at set temperature.  My 97, seems to cycle on earlier, and run for shorter periods, and my 99 later, but runs longer. Just curious, as I should probably do a complete coolant drain, cleanse,  and refill, then see if it is any different
mello dude
Dayton Ohio
« Reply #1 on: August 12, 2019, 07:18:51 PM »
HI --
1999 radiator part list....
https://www.partzilla.com/product/honda/37760-MT2-003?ref=ed5006eed1aa2334db901a1e6786f194b85a44cc
1997 Radiator part list....
Same part number - guessing it may a good idea to drain, flush and refill both... or the one that cycles too much...
« Reply #2 on: August 12, 2019, 07:49:30 PM »
Could be the state of tune. A leaner carb mixture will run a bit hotter causing differences in fan operation.
mauigts
Maui, HI
« Reply #3 on: August 12, 2019, 11:35:32 PM »
Thanks. The 99 seems fine runs for a while, in traffic, shuts off once moving, seems normal. My recent purchase 97, seems to be different. I am planning to change the plugs, coolant, oil, filter(s), etc. Mainly just wondered if there were optional  fan thermostats, as in Honda figured out that  adjusting the on off settings worked better as they progressed through the  years. This 97 is in Hawaii, and this summer, we might as well be in Florida with the temps and humidity, (very unusual), but of course so I'm told ,there no global warming. I'll update, if after some maintenance, the fan operation changes from what it is now. Maybe I'll check the thermistor too, in a pot of water just to see when it closes.
