December 31, 2025, 01:20:46 AM *
Author Topic: All years front rotors interchangeable?  (Read 2880 times)
Tfrank59
'98 Tourer
Western Washington
« on: August 29, 2019, 03:40:22 PM »
 There are probably some posts about this but you gurus in the know can you tell me if I use a front rotor off of a 2000 Interstate would it fit on my 1998 tourer?  I'm thinking all those years  front rotors are interchangeable but I wanna check especially cause it's coming off of an interstate.
-Tom
« Reply #1 on: August 29, 2019, 04:04:49 PM »
I don't know, but that is what I recall. GW or Valk, the same.
I went on procaliber. The 99' CF and the 98 C are the same.
« Reply #2 on: August 29, 2019, 04:07:41 PM »
All interchangeable
Tfrank59
'98 Tourer
Western Washington
« Reply #3 on: August 29, 2019, 04:14:27 PM »
Thanks!
-Tom
« Reply #4 on: August 29, 2019, 05:04:15 PM »
only goldwing GL1800 fits,  GW GL1500 does not fit.
Tfrank59
'98 Tourer
Western Washington
« Reply #5 on: August 29, 2019, 06:17:46 PM »
That's good to know thanks
-Tom
« Reply #6 on: August 30, 2019, 04:12:59 PM »
As a FYI, the GW GL1500 rear rotors are the same for the Valk.
Paladin528
« Reply #7 on: August 30, 2019, 05:35:57 PM »
but not all years.  the rear rotors are different from 99 on
Tfrank59
'98 Tourer
Western Washington
« Reply #8 on: August 30, 2019, 09:49:06 PM »
Yeah I know the rear rotors are different but I'm asking about the fronts which I was pretty sure were the same all the years
-Tom
ridingron
Orlando
« Reply #9 on: August 31, 2019, 09:05:46 AM »
Front rotors are the same part number and price..
2000 I'state;  https://www.partsfish.com/oemparts/a/hon/506c2f95f870023420a31bdf/front-wheel
1998 Tourer: https://www.partsfish.com/oemparts/a/hon/506cb66ff870023420a41843/front-wheel
« Reply #10 on: August 31, 2019, 10:39:31 AM »
other honda front rotors that fit. I use a set of VFR800 ebay $100 were within new spec range per VFR800 service manual.  I like the carrier look very much.
Front OEM valkyrie rotors = 3.25 lbs ea
Both are the same and fit the valkyrie.
Front VRF800 rotors = 2.75 lbs ea
Front CBR600F4 rotors = 2.75 lbs ea
Tfrank59
'98 Tourer
Western Washington
« Reply #11 on: August 31, 2019, 12:57:30 PM »
That's great to know thanks!
-Tom
Paladin528
« Reply #12 on: September 01, 2019, 02:56:32 PM »
What is the new thickness of the CBR and VFR rotors?
The reason I as is that the Valk Minimum Thickness is 4mm.  This is important because the Valkyrie is FAR heavier than either of those 2 bikes.  The extra metal on the VALK rotors allows for More heat to be absorbed.
The Calipers and pads are also designed for a thicker rotor.
« Reply #13 on: September 01, 2019, 03:33:57 PM »
EBC lists same rotor for all, doesn't see a problem. I am seeing better braking with the OEM VFR800 rotors than from the OEM Valkyrie. Holding heat gives less braking performance. cooler brakes the better during operation.
 EBC Brake Rotor #MD1014X Fits Honda Goldwing/Valkyrie/VFR800/CBR 600/CBR 900  https://www.ebay.com/itm/EBC-Brake-Rotor-MD1014X-Fits-Honda-Goldwing-Valkyrie-VFR800-CBR-600-CBR-900-/333304180504?_trksid=p2349526.m4383.l4275.c10#viTabs_0
