December 31, 2025, 09:10:24 AM *
Author Topic: Clutch Master Cylinder  (Read 1599 times)
6adan
Zip City, Alabama
« on: August 29, 2019, 06:28:26 PM »
  Can anyone tell me if there is another master cylinder from another Honda that is the same as the Valkyrie? I need one for the bike I have because the mirror threads are bad. if there is one that will give me a better chance of finding one.   Thanks Dannie
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
nogrey
Nampa, Idaho
« Reply #1 on: August 29, 2019, 08:32:38 PM »
Which master cylinder are you referring to? The clutch, or the brake?
6adan
Zip City, Alabama
« Reply #2 on: August 30, 2019, 02:44:25 AM »
Clutch
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: August 30, 2019, 02:53:05 AM »
Clutch
New ones are not that expensive. I think mine was less than $80.
« Reply #4 on: August 30, 2019, 03:02:26 AM »
https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500cf-a-valkyrie-interstate/clutch-master-cylinder
https://www.partzilla.com/product/honda/22890-MZ0-A41?ref=d9e91b87205189aa7fdc475040f08abbc14a8697
https://www.ebay.com/itm/03-Honda-GL-1500-Valkyrie-Clutch-Master-Cylinder-81J/153621107694?hash=item23c48813ee%3Ag%3AihoAAOSwcXNc3MPO&LH_ItemCondition=4
« Reply #5 on: August 30, 2019, 03:08:45 AM »
Some years, though, are marked "unavailable"... 97 Tourer is one...
« Reply #6 on: August 30, 2019, 03:29:13 AM »
Yeah Mike, I saw that.  While I can't say for sure, pretty sure all Standards and Tourers use the same one and the only difference I could see on the Interstates was the clamp piece, yet it's listed in $90 range.
98 Tourer, unavailable, 99 Tourer $79 in stock.
Don't believe the master cylinder is used on any other honda, but that doesn't mean some other models wouldn't work.
Seems like a lot of work trying to figure out which one would.
Gnarly
FlyinJenni2
Resume Speed,KY
« Reply #7 on: August 30, 2019, 05:55:59 AM »
This one will interchange, but likely more expensive!
Not positive, but I THINK it was OEM for the VTX 1800's.
I paid $137.40 at Partzilla.
My thanx to Sundaram Raman, a friend and member here. He is a wise man.
Bought it simply because of approximately 50% less 'squeeze pressure' needed.
Old left hand injuries made it worth replacing the original clutch cylinder, to me.
Hope this helps others as well: 22890-MCH-006 - M/CYL SUB-ASSY
I've loved many bikes, over the last 52 years of riding, but this Valkyrie machine may have propelled me headlong into IDOLATRY....
Leathel
New Zealand
« Reply #8 on: August 30, 2019, 01:39:17 PM »
From memory the VTX has a slightly smaller piston clutch master.... which will work and give you a lighter clutch to use but has a little more movement to work.... I looked at swapping them but never got around to it Smiley
6adan
Zip City, Alabama
« Reply #9 on: August 30, 2019, 03:04:19 PM »
  Thanks everyone, that is just what I needed.
« Reply #10 on: August 30, 2019, 05:42:15 PM »
There have been filks that have replaced them with HD masters with no problems. Q master cylinder is a master cylinder. Getting it to mount to your buke is a different problem all together.
