December 31, 2025, 09:10:15 AM
Stop-light working intermittently
Topic: Stop-light working intermittently (Read 1049 times)
berto
September 01, 2019, 10:49:08 AM »
Hi Everybody.
Was checking the brake lights before riding and discovered: they not always work. Not the brake switches at the lever or pedal as the Brake-light either works with both or not at all. ?!?!?
Any suggestion ?? Is there a relay possibly responsible ??
Thank you
Re: Stop-light working intermittently
September 01, 2019, 12:23:31 PM »
Dont think it would be a relay. Loose wire or bad ground somewhere would be my guess. Also try a new bulb. Easy stuff first.
Jruby38
Oxford Mass.
September 01, 2019, 02:23:47 PM »
Happened to me. The fix was to squeeze the switch terminals with needle nose pliers.
September 01, 2019, 02:42:51 PM »
My front brake handle required a new switch recently.
The foot brake, needed adjustment to make it work.
That was all last year. This year, starting to ride again, I had the rear light not working. Turned out it was the foot brake pedal not coming back, and the light was on all the time. Spray lube and worked it a lot, and it's not sticking on any longer. Something I'll need to inspect again after it's winter storage.
berto
September 01, 2019, 03:21:49 PM »
Found-it. Had to crawl under the rear fender to see the green/yellow lead had come loose, erase fix
Thanks for the quick replay
=> InZane XXV
