January 30, 2026, 03:42:27 AM *
Author Topic: Problem: seeing the speedo/tach digits at night/evening  (Read 3580 times)
Tx Bohemian
Victoria, Tx
« on: December 02, 2009, 05:49:06 AM »
Maybe it's the age thing but I have a hard time seeing the needle and the digits on the speedo and tach once the sun goes down, basically at night.
All the lights are lit up (or so I think) but I just can't see what number the needle is pointing at.  I think it's due to the white face and the light blue numbers on the face. Plus the numbers are small. (and at 53 my eyesite isn't what it used to be)
I did a quick search but didn't find anything like different faces and/or needles that I could replace the factory stuff with.
Does anyone know if there is anything out there like that (replacement faces) short of replacing the complete speedo/tach?
Al
« Reply #1 on: December 02, 2009, 06:02:15 AM »
http://www.horseapple.com/Valkyrie/Tech_Tips/Improving_Indicator_Light_Visi/improving_indicator_light_visi.html
should have been this link
http://www.horseapple.com/Valkyrie/Tech_Tips/Instrument_Lights/instrument_lights.html
« Last Edit: December 02, 2009, 02:41:23 PM by CA ExhaustCoatings » Logged
« Reply #2 on: December 02, 2009, 06:04:37 AM »
How about changing the bulbs to either #158[3.3w] or #194[3.9w].. #168[4.9w] will also work but develops an awful lot of heat..
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: December 02, 2009, 09:03:24 AM »
CA, these aren't what the o.p. is asking about.  These instructions are for the lights in the headlight shell not the indicators in the gauges.  Tx, you could try to find the earlier gauges which use orange light plus increase the brightness of the bulbs.
Marty
« Reply #4 on: December 02, 2009, 02:43:17 PM »
updated
« Reply #5 on: December 02, 2009, 04:23:48 PM »
It doesn't show them as good as they actually are in person, but you can see/read them in any light. I did it mostly to match the blue LED backlighting on the small gauges. Looks really neat at night.
« Reply #6 on: December 02, 2009, 04:47:33 PM »
OK dear! I found some license plate mounting bolts at Advance Auto Parts that have the LED's in the center. You can get them just about anywhere and various colors. Then I simply mounted and wired them into the headlight bucket, used a source that only comes on with the key but don't recall which wire it was just now. Easy enough to figure out though. The attached picture shows work in progress for the mounting. I had some thin SS angle scrap metal and cut, drilled, and ground them to the shape you see. I used a piece of SS tubing to cut a spacer large enough to allow them to clear the gauges. Initially the light was too concentrated and only lit up the center of the large gauges, so I just smeared a dab of clear RTV on the end of the LED bulb and it diffused the light enough to flood the entire gauge face. As you can see, it's a clean installation/look, and I've hade them on there for a couple years at least.
Jack B
Two Rivers Wis
« Reply #7 on: December 02, 2009, 05:26:21 PM »
I have a mint green & black 98 tourer and my light is green, on the other posts one said he had blue and another said orange. So are the color of the lights match the bike mmmm then a black bike would have a black light ?? but those are so fast they don't need any light.....
Let’s RIDE
« Reply #8 on: December 02, 2009, 09:21:49 PM »
"Tx, you could try to find the earlier gauges which use orange light plus increase the brightness of the bulbs."
What earlier models?  I have a '97 red & white standard with a serial number of 383.  That's about as early as it gets.....and it has the green numerals.
I have however, seen a video of a Valk (it was black, but I'm not sure model/year) on youtube that did indeed have the orange numerals.
Are there model or year specific Valks that do have the orange speedo and tach?  Do they have a different part number than the green ones?
I'd love to be able to source a set if I can find them.
Redline +
Northwest Washington
« Reply #9 on: December 02, 2009, 10:51:18 PM »
My black/red '02 has the orange.
Redline  Cool
Colin
My old job
Orba, Spain
« Reply #10 on: December 03, 2009, 04:20:11 AM »
I am pretty sure my 1996 has orange too (it is in pieces at the moment so I cannot confirm).
Colin
VRCC Espana
My Bumble Bee re-build
MP
North Dakota
« Reply #11 on: December 03, 2009, 05:18:42 AM »
I believe the early ones were green, then switched to orange.
"Ridin' with Cycho"
Ferris Leets
Catskill Mountains, N.Y.
« Reply #12 on: December 03, 2009, 07:27:14 AM »
So how did you get them to be that bright?
« Reply #13 on: December 03, 2009, 11:39:08 AM »
Which are you referring to....the small gauges or the OEM? The small ones come that bright, they have blue LED internal backlighting. For the large ones, see my photo above showing how the lights are mounted. The blue LED in the license plate bolts are very bright and I just aimed them at the face of the gauges, the beam lights them up like that.
Ferris Leets
« Reply #14 on: December 03, 2009, 11:51:47 AM »
I see now.
houstone
Can't get enough...
Santa Fe, TX
« Reply #15 on: December 03, 2009, 12:41:04 PM »
Light can't keep up with the fast black, which is why they are!
  coolsmiley
Tx Bohemian
Victoria, Tx
« Reply #16 on: December 03, 2009, 02:34:40 PM »
  coolsmiley
Well, that explains it!  My bike is black, thanks!!
Now that I think of it, that may be why all the chrome on the front forks is peeling too, I thought it was just a bad plating job!!
Al
« Reply #17 on: December 03, 2009, 04:19:15 PM »
Yup, I had the same problem with those blue LED's. My bike is black as well and without the addition of the fairing they kept washing out. I guess the fairing slowed the wind down enough so the light could catch up.  Roll Eyes
X Ring
« Reply #18 on: December 03, 2009, 07:30:17 PM »
My '97 had orange gauge lighting
