December 31, 2025, 06:52:37 AM *
Author Topic: Inner Speedo cable removal ?  (Read 1206 times)
Lyle Laun
Calgary, Ab
« on: September 07, 2019, 07:05:12 PM »
The speedometer inner cable on my standard failed. I removed the cable from the speedo and pulled out the inner cable. It appears to have broke off about 4” up from the hub. I them removed the whole cable and am trying to remove the 4” of the failed inner cable.
My question(s)
- what is on the bottom end of the inner cable ?
- Shouldn't the failed piece just drop out of the bottom of the cable ?
 It isn't dropping out, I assume it's the failed inner cable holding it up, any ideas how to get it out or do most of you just replace the complete cable ?
Lyle Laun
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #1 on: September 07, 2019, 08:18:12 PM »
Lyle,
Looks like you can buy inner only, but if I were a betting man I would guess the housing has been compromised and replace the whole unit.
Less than $20 from Rocky Mtn Parts
https://www.rockymountainatvmc.com/oem-schematic/20
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #2 on: September 08, 2019, 03:59:19 AM »
Grab the end of the cable and swing it around rapidly.
Lyle Laun
Calgary, Ab
« Reply #3 on: September 08, 2019, 07:55:58 AM »
Thanks guys, I will get a new one on order.
Regards
Lyle
Get out & Ride !!
Tfrank59
'98 Tourer
Western Washington
« Reply #4 on: September 08, 2019, 08:31:16 PM »
 yeah I went the route of replacing just the inner cable and it only lasted a couple thousand miles before it broke, and then I bought a whole new cable including the outer casing and it's been lasting for 30k so far. Curious I guess it's not in your post but how many miles on your bike before it broke?
-Tom
vanagon40
Greenwood, IN
« Reply #5 on: September 09, 2019, 08:13:40 AM »
. . . Looks like you can buy inner only, but if I were a betting man I would guess the housing has been compromised and replace the whole unit. . . .
yeah I went the route of replacing just the inner cable and it only lasted a couple thousand miles before it broke, and then I bought a whole new cable including the outer casing and it's been lasting for 30k so far. . . .
I agree.
My cable broke at 36,000 miles. I replaced only the inner cable. It broke again at 43,000 miles: I replaced only the inner cable. It broke again before 50,000 miles: I replaced the entire cable.
Always broke at the same spot, but I could see no damage to the cable (and was not aware of any external cause that might have damaged the cable).
Bagger John - #3785
« Reply #6 on: September 09, 2019, 11:14:36 AM »
How often are you folks removing, cleaning and re-greasing the inner cable?
I do mine every couple of years or at an air-filter change, whichever comes first. A good synthetic grease (Park's cycle grease or similar) is what I've used throughout.
Bone
« Reply #7 on: September 09, 2019, 11:30:07 AM »
Mine broke at 115k the new one has 45k.
Haven't lubed either one.
Tfrank59
'98 Tourer
Western Washington
« Reply #8 on: September 09, 2019, 02:31:37 PM »
 well there may be something to that cleaning and oiling thing because the OEM cable on mine broke at about 35k, and the new one that I put in there has gone about 50k or more (and I've never lubed it). But I wonder if the original one would have gone farther had I or the previous owner cleaned and lubed it Roll Eyes
-Tom
Bone
« Reply #9 on: September 09, 2019, 04:13:43 PM »
I don't remember my broken cable being dry.
There is a lot of things I don't remember  Embarrassed
Tfrank59
'98 Tourer
Western Washington
« Reply #10 on: September 09, 2019, 05:31:53 PM »
 Yeah I hear you about the forgetfulness thing. But you got some really good life out of your OEM cable if yours made it to 115 K, as I said mine only made it to about 35k. Actually I didn't even know speedometer cables require maintenance and not saying I'm going to do the maintenance.Grin
-Tom
Lyle Laun
Calgary, Ab
« Reply #11 on: September 09, 2019, 06:28:52 PM »
I don’t know the mileage on this cable but my other standard speedo cable failed around 45,000 miles. I've never lubed them and at less than $20 for a complete cable, I might not ever bother.
Lyle
Get out & Ride !!
