December 31, 2025, 06:52:37 AM *
Author Topic: Little help pleas. HANDLEBAR HEATER.  (Read 1071 times)
gregk
Retired
Chippewa Falls, wi.
« on: September 11, 2019, 06:24:57 AM »
I have a heater i never fully hooked up. Its one of those paper ones that lay on the handlebar.  That I had done, with the wires going through the handlebar. 3 wires for low heat and high heat Red, Green, Blue.  I also bought a toggle SW. (on/off/on) And I have a hot wire for supply to the SW.   How do I connect the 3 wires. Thinking one must be a ground, right ?
   If so I should be able to do a resistance ck across the wires to find which one goes for the high heat and whicn goes for the low heat right?
da prez
Wilmot Wi
« Reply #1 on: September 11, 2019, 04:07:08 PM »
Rule of thumb (?)  green would be the ground.
        da prez
gregk
Retired
Chippewa Falls, wi.
« Reply #2 on: September 12, 2019, 04:45:30 PM »
Got it ,10ohms Grn-b, 5 y -grn , 5 blu-y
                  Grn-ground , blu- high, y-low
Had heat in 4 blocks . no fire.
