February 12, 2026, 11:11:57 PM *
Pages: 1 [2]   Go Down
Author Topic: Airbox re-assembly & Pair Valve delete w/Redeye Shiny Desmog kit -MD Tech  (Read 8010 times)
mello dude
Dayton Ohio
« Reply #40 on: October 08, 2019, 05:00:12 PM »
Dab a bit of red locktite on it... fumble and get nut on... Ok, this sucker is not coming off! Roll Eyes
Wish I had thought of this before I installed the airbox back on!  Tongue
Done! Permanatly! Yay!  Cool
Update note June 2022 -- Lowes has a 7mm dia bolt that probably would fit better with out having to drill the airbox hole out... if there is another time.... I will do this with the airbox off the bike.
« Last Edit: June 26, 2022, 10:35:52 AM by mello dude » Logged
RonW
Newport Beach
« Reply #41 on: October 08, 2019, 06:06:00 PM »
Why you never face the bolt up? Nevermind, wink.
2000 Valkyrie Tourer
mello dude
Dayton Ohio
« Reply #42 on: October 08, 2019, 06:51:22 PM »
Aw...C'mon stop it! lol!  Grin
 Cool
« Last Edit: October 08, 2019, 07:00:07 PM by mello dude » Logged
luftkoph
E U.P. Mich
« Reply #43 on: October 10, 2019, 07:53:23 AM »
Keep an eye on those Dorman plugs, I've used them on my ZRX and they started to dry rot in about a years time.
Lot of vacuum caps are meant to be used for testing purposes, not as a permanent install. The material might not do well exposed daily to sunlight etc. Where specifically on your ZRX did you use the Dorman plugs? Dorman caps are vinyl and vinyl might deteriorate even with the airbox location, dunno.
Anyways, should the PAIR spout on the Valk airbox be capped or plugged? Just thinking aloud .
Kawasaki used an air injection, or more like a vacuum that was prone to sucking engine oil, so it was an airbox cap also, I remember using them some place else, and same problem they would dry rot.
Some day never comes
Pages: 1 [2]   Go Up
