November 13, 2025, 04:15:48 PM *
Author Topic: 205 CT on 5 inch rim ok?  (Read 987 times)
HBFL
« on: September 24, 2019, 09:20:23 AM »
Going dark again can’t remember the size of the CT I took off. 5 inch ok for 205? Better with 195 or 185?
vanagon40
Greenwood, IN
« Reply #1 on: September 24, 2019, 11:24:49 AM »
I use a 205/60-16 on the stock rim with no problem. This size usually requires a modification of the nut cages under the fender.
A 205/55-16 is slightly smaller in diameter and will not likely require and modification.
Some have used a 205/65-16 which is slightly larger in diameter and almost assuredly will require modification of the nut cages.
