November 13, 2025, 04:16:01 PM *
Author Topic: Running hot!  (Read 1052 times)
Tuanis
Costa Rica
« on: September 24, 2019, 12:58:38 PM »
My 1500 Gl develop a overheating problem on a week long ride through Tennessee. One day I notice the high temperature light was on, but the fan was not running. a minute later the fan started, but stopped before the red light went off. The next day everything ran fine for a few hours and then the problem returned. I have shorted out the fan sender and the fan runs continues. I'm thinking it's a bad sender unless someone has another solution.
As always thanks for the input!
« Reply #1 on: September 24, 2019, 01:37:04 PM »
have u done any re-jetting?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: September 24, 2019, 03:08:01 PM »
Enough fluid? Water pump pumping? If so on those, it’s about a 95% chance it’s the recurring issue of the 97-99 unit that makes the light come on. Check the search for this.
« Reply #3 on: September 24, 2019, 04:27:15 PM »
Valker is right. The 97-99's often give false hot lights. Pay attention to the fan (on auto) for a true sign of overheating.
Bagger John - #3785
« Reply #4 on: September 25, 2019, 05:22:08 AM »
What was the ambient temperature during your ride?
Last Sunday - in stop-and-go traffic - my I/S's coolant was running anywhere between 205 and 220 degrees F as indicated on the aftermarket (Stewart-Warner) temperature gauge. The outside air temp was in the upper 80s. Freeway riding @ 65MPH or so would drop the coolant temp to around 190F.
As long as the fan comes on then goes off (indicating that it's properly dropping the coolant temperature) I would overlook the temp light on your model year of bike. Better still, convert the thing to 2000-up MY functionality. There are a few threads in this forum on how to do it.
