November 13, 2025, 04:16:05 PM *
Author Topic: Clutch Master Cylinder Question  (Read 983 times)
Jruby38
Oxford Mass.
« on: September 26, 2019, 05:21:11 AM »
Are all Clutch master cylinders the same for all models, or is the Interstate different?
« Reply #1 on: September 26, 2019, 06:18:22 AM »
Standard and Tourer have a different part number than the Interstate.  All the associated parts (piston set, switch, cover, etc.) appear to be the same part numbers, and the main casting appears to be the same.  Not having each side-by-side in front of me, I can't be sure, but the only difference I can see looking at photos is the clamp for mounting to the handlebars, with the IS version having accommodations for mounting the switch box for the radio, etc.  So, from what I can tell, the master cylinders themselves, without the clamp, are interchangeable.
