November 13, 2025, 04:16:02 PM
2003 Valkyrie cd Timing Belts
Topic: 2003 Valkyrie cd Timing Belts (Read 1172 times)
Calboy
September 26, 2019, 12:18:10 PM »
Went on Amazon to purchase two of these belts, which I did.
A few minutes later I checked to make sure they fit the year, make and model, and to my surprise it shows that these particular belts do not fit!
I got my info from these message boards. I ordered the T-275 belts.
Error on Amazon or actually I need other belts to fit. Gates looks like a winner but I must make sure that I pick the right ones.
2003 Valkyrie CD (California model)
Re: 2003 Valkyrie cd Timing Belts
September 26, 2019, 12:49:00 PM »
I'm 99.9% sure that all Valkyrie models take the same belts.
6adan
Zip City, Alabama
September 26, 2019, 01:31:27 PM »
That is the same belts that work on the GL 1500 Goldwing.
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
September 26, 2019, 03:26:13 PM »
generic page of parts in Shop talk.
http://www.jkozloski.com/generic_parts.htm
All 275 belts are the same (ok, not all). It's like bearings, if the # match, you've the right one.
September 26, 2019, 05:07:02 PM »
I'm not testifying to the correct belt size, but I will testify that in all my considerable dealings with Amazon, I have had them come up on the page and tell me something will not fit (or properly match up), when it is absolutely the right part and does fit (when it arrives). Not just motorcycles either.
Amazon webpage opinions on fitment (for anything) are only accurate some of the time. (i.e. not to be trusted)
I have Gates 275s on both my bikes.
Last Edit: September 26, 2019, 05:11:03 PM by Jess from VA
Calboy
September 27, 2019, 08:06:40 AM »
Thank you very much for your replies.
mello dude
Dayton Ohio
Reply #6 on:
September 28, 2019, 05:11:42 PM »
Looks like ALL Honda 1500 engines use the same belts...
https://www.partzilla.com/product/honda/14401-MN5-004?ref=77d8b21e77ffa32ade16bd7c0cdc79c2953326ad
=> InZane XXV
