November 13, 2025, 02:14:30 PM *
Author Topic: Forks rebuilt with Goldwing 1800 progressive springs  (Read 1158 times)
Warlock
Magnolia, Ms
« on: October 01, 2019, 12:26:06 PM »
My right one has been leaking a while and was trying to hold out till my rake kit arrives. That will be another 30 to 40 days. Anyway pulled the right side down and found oil seal had been damaged I guess by someone attempt . All sliders and bushing bad both sides. The right side that wasn't leaking only had about 10 oz of oil in it. Before I rebuild them I had 3 1/4 on my forks and didn't take much to bottom out. Both stock springs was out of spec. Love the progressive springs I put 22 oz in the right one and 24 oz in the left one. I used ATF dexron/merc fluid. Rides so much better and now has 5 3/8 free play in the forks. Also found bad wheel bearing and I had ordered some new ones with dust seals. Had to replace brake pads due to the fork oil had soaked them. All is better now and rides like a new trike.
David
« Reply #1 on: October 01, 2019, 01:42:49 PM »
Sounds great... I wonder what 1800 progressive springs in a two wheel Valkyrie
would be like?
Gideon
Indianapolis, IN.
« Reply #2 on: October 01, 2019, 02:17:09 PM »
David
David, with you mentioning that you put 22 ounces in the right fork and 24 ounces in the left fork , I have to ask what air pressure do you have in the two rear tires.
I too ride a Trike.
Bob  aka Gideon
3W-lonerider
Shippensburg Pa
« Reply #3 on: October 01, 2019, 02:21:12 PM »
I normally kept 24 psi in the rear tires and 38 in the front tire. I kept the front tire low because my shoulders didn't like the jolt very much when i would hit. Pothole.
Warlock
Magnolia, Ms
« Reply #4 on: October 01, 2019, 02:23:39 PM »
David
I too ride a Trike.
Bob  aka Gideon
I'm running 22 lbs in my rear tires and 38 front tire.
David
« Reply #5 on: October 02, 2019, 05:12:37 AM »
I too had to change front brake pads due to the forks leaking. Make sure the rotors aren’t impregnated with oil. I had to use lots of brake cleaner and steel wool until they were clean. Brakes didn’t have any stopping power until the rotors got clean
Warlock
Magnolia, Ms
« Reply #6 on: October 02, 2019, 07:52:49 AM »
Used a whole can of brake cleaner plus scrubbed them with dawn dishwater soap. Looked like a new rotor when I got threw. Once it hits the pads they are no longer any good. They sit in a bad spot when the seals decides to leak and fall right on the brake pads.
David
Gnarly
FlyinJenni2
Resume Speed,KY
« Reply #7 on: October 02, 2019, 02:24:35 PM »
would be like?
My thoughts, exactly!
Just may try that, at my next scheduled maintenance in mid-November.
I've loved many bikes, over the last 52 years of riding, but this Valkyrie machine may have propelled me headlong into IDOLATRY....
