November 13, 2025, 02:14:26 PM *
Author Topic: Do 1800 Rear Drive splines fit the 1500?  (Read 1207 times)
Jersey
VRCC #37540
Southern Maryland
« on: October 23, 2019, 08:16:31 AM »
Another question for the more-well-informed (than I)...  I understand the GW 1500 splines can be pressed into the rear drive gear on our Valks... but curious if the same can be done using the VTX1800 splines?
Jersey
« Last Edit: October 23, 2019, 11:01:39 AM by Jersey » Logged
Jersey
indybobm
Franklin, Indiana VRCC # 5258
« Reply #1 on: October 23, 2019, 01:41:15 PM »
That is an interesting question. The VTX Final Drive looks almost like a mirror copy of the Valkyrie.Final Drive. The internal parts turn in the opposite direction. According to the parts fiche, big ring gear bearing has different dimensions and a different part number.
So many roads, so little time
VRCC # 5258
Jersey
VRCC #37540
Southern Maryland
« Reply #2 on: October 23, 2019, 06:13:57 PM »
I just found a closeup pix of the 1800... doesn't look the same on the inside dimensions of the spline cylinder itself.  Probably won't work.
Jersey
