December 31, 2025, 05:01:35 AM
Need a Valk Mechanic in South Florida
Topic: Need a Valk Mechanic in South Florida (Read 1400 times)
mmvalk
Boynton Beach, FL
October 27, 2019, 07:49:07 AM »
Let my 1999 Valkyrie sit too long and she can't maintain an idle. Starts fine with the choke fully engaged but stalls when at idle. I drained the carbs, put in about 2.5 gallons of ethanol-free fuel and a full can of Seafoam and then Berryman B-12 (sat for a day). Took it out this morning and rode it around my area hovering at 2k RPM. Still no joy, still stalls when stopped.
May need a competent Valkyrie mechanic in my area (Boynton Beach), if the B-12 doesn't clear the low-speed jets.
Appreciate any recommendations.
Re: Need a Valk Mechanic in South Florida
October 27, 2019, 08:36:45 AM »
Have you tried adjusting the idle screw ?
mmvalk
Boynton Beach, FL
October 27, 2019, 10:44:03 AM »
hmmm, hadn't thought of that... don't have access to my service manual... would you know the location of the idle screw? and do I need a special tool?
Thank you
mmvalk
Boynton Beach, FL
October 27, 2019, 11:32:11 AM »
found the adjustment screw and pumped up the idle to ~900.... any idea why the precipitous drop in idle speed?
October 27, 2019, 11:56:36 AM »
Sorry, just got back to this. If I was to guess, I’d say some of your slow jets might be slightly clogged. Maybe run some different cleaners thru it. Techron, etc.
mmvalk
Boynton Beach, FL
October 27, 2019, 01:09:30 PM »
thanks much. will do!
Rhino
Reply #6 on:
November 29, 2019, 06:25:28 PM »
I don’t have a mechanic to refer. Wish I did.
So far just changing my own oil, or I ride to Rick Case.
Let’s ride! I am in Boynton Greenacres area.
=> InZane XXV
