December 31, 2025, 05:01:36 AM *
Author Topic: Hard bags install  (Read 1919 times)
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« on: November 04, 2019, 10:44:04 AM »
Hello  Valkers,
 I have a set of Interstate  hard bags that I want to put on my 03 standard, can someone  tell me how to do this Please.
Tony
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
F6BANGER
Albuquerque NM
« Reply #1 on: November 04, 2019, 11:17:38 AM »
Do you have mounting brackets/supports?
Steel cowboy
Spring Hill, Fl.
« Reply #2 on: November 04, 2019, 11:19:37 AM »
You will need to purchase a set of these brackets.
https://www.ebay.com/itm/00-Honda-Valkyrie-Interstate-GL1500-Saddlebag-Mount-Stay-Bracket-Support-Set/163796035281?hash=item26230126d1:g:aR4AAOSweK9dPv-O:sc:FedExHomeDelivery!34608!US!-1
2001 black interstate
2003 Jupiter Orange wing
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #3 on: November 04, 2019, 12:39:15 PM »
I have the brackets but,  I'm thinking I need longer bolts and some sort of spacers.
« Reply #4 on: November 04, 2019, 01:02:39 PM »
The way you do this is to pull up an OE parts diagram and parts list, print it out, and study it for the hardware you need.  It's helpful if you can blow up the assembly picture before printing.  The actual hardware parts are described in the accompanying parts list.
Either order OE Honda parts, or take a list to a good hardware store and buy stainless.  Now when the OE part calls for a flange bolt (chrome with built in washer), you get a good stainless hex bolt and stainless washer in substitution.
This is one of the more detailed parts diagrams (so put your bifocals on  Grin).  I used a 99 interstate fish (my bike), but they are all the same for CF and CT bag mounts.
https://www.procaliber.com/oem-parts?aribrand=HOM&arian=MOTORCYCLE#/Honda_Powersports/GL1500CFA_(99)_VALKYRIE_INTERSTATE%2c_USA%2c_VIN%23_1HFSC410-XA000001/SADDLEBAG/GL1500CF-99-A/14MBYXE1AMBY4F3900AC/y
« Last Edit: November 04, 2019, 01:07:15 PM by Jess from VA » Logged
RonW
Newport Beach
« Reply #5 on: November 04, 2019, 04:28:50 PM »
My tourer bags requires just 4 bolts per bag. 2 on the bottom and 2 on the sides. Each bolt has a rubber grommet and a collar that prevents over-tightening the bolts. Are you asking about the bolts that secure the brackets to the frame? The bags then bolt on to the brackets.
2000 Valkyrie Tourer
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #6 on: November 04, 2019, 08:28:10 PM »
Thank you very much, I went the local hardware store's and found what I needed.
