December 31, 2025, 05:02:50 AM *
Author Topic: 2001 Standard Tach not working after sitting  (Read 1535 times)
ryord
« on: November 08, 2019, 09:55:47 AM »
Hello, I have had this problem before and the tach recovered after a few starts, the tach was replaced new about 5 years ago when the original went bad and ended up on the wrong side of the rest guard, I used a magnet to get it back but decided to replace it. I have checked the ECM Module with another, I have checked the connections in the light bucket, I have not replaced it with the old tack yet. Any suggestions would be appreciated. Thanks  Rick.
« Reply #1 on: November 08, 2019, 10:12:33 AM »
Put a volt meter on the battery with the bike running. If it’s not near, at or slightly over 14v then your alternator can be the culprit
ryord
« Reply #2 on: November 09, 2019, 12:26:07 PM »
I will try that, Thanks Rick
Gideon
Indianapolis, IN.
« Reply #3 on: November 27, 2019, 06:50:31 AM »
If that is not the problem, you might have electrical problem with the ignition switch. The ignition controls three different circuits: IG1, IG2,and FAN. The IG2 controls the tachometer, taillights and head light. I had a problem with the IG2 circuit. Rather than wait for several weeks for a new ignition switch, a friend installed a separate wire with a relay and a 30-amp fuse for the IG2.
ryord
« Reply #4 on: December 11, 2019, 06:01:01 PM »
The last time I started the bike for a ride about a week ago the tach miraculously came back to life, could you give me more info on the modification to the ignition you where taking about. Thanks Rick
