November 20, 2025, 01:32:30 PM *
Author Topic: 2000 Interstate exhaust  (Read 1984 times)
wiplash123
« on: December 05, 2009, 06:51:50 AM »
 I know everone has prodeley answered this question hounderds fo times dut I need help!!
I have my stacks and was going to cut the rear baffles off and keep it to use to tune it down fi needed
and remove when I wanted to. I am not sure if front baffles have been driled or not. If they have would
I have enough back pressure or not. I don't to have to rejet the carbs or would it be better to go with
glasspacks Undecided
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: December 05, 2009, 07:31:45 AM »
Sometimes, but only if the exhaust is modified. Jetting is not to be taken lightly as there are too many variables for those not familiar with multiple CV carbs.
ALWAYS QUESTION AUTHORITY!
« Reply #2 on: December 05, 2009, 08:26:57 AM »
My rears are drilled and I cut 3-4" off the muffler and I have no need to rejet. I haven't looked at my plugs but seen no performance decrease in hacking mine off. Might even cut more off later. If your back baffles were not touched then its a good chance the fronts are also untouched. I don't recall another way of getting in there with out going through the back door.
wiplash123
« Reply #3 on: December 07, 2009, 06:20:59 AM »
 Thanks for the help !!!!!!
frosty
« Reply #4 on: December 09, 2009, 06:01:29 AM »
May want to ck. shoptalk for the exhaust glasspack mod. Sounds like your going in that direction. With removable baffles for the dif. sounds.
