December 31, 2025, 03:18:17 AM *
Author Topic: Switch For 99 Interstate Pod Lights  (Read 1729 times)
GRCTAMPA
Tampa, FL
« on: November 24, 2019, 01:31:25 PM »
Thanks to the great resources on this forum I was able to replace a bad relay and get the pod lights working again. Now, the issue remaining is the switch does control the lights. Fortunately, they are on all the time. I would prefer not to try to open and clean the switch as others have commented it has numerous small pieces. Does anyone have a source for a replacement switch? I can live with the lights always on but would prefer to have an operable switch. Thanks again for all the great info on this board.
« Reply #1 on: November 24, 2019, 09:29:09 PM »
Try electrical connections. He may have a replacement.
GRCTAMPA
Tampa, FL
« Reply #2 on: November 25, 2019, 03:33:09 AM »
Thanks, I emailed them this morning.
GRCTAMPA
Tampa, FL
« Reply #3 on: November 25, 2019, 05:59:17 PM »
Electrical Connections responded they do not carry a replacement switch. Anyone have an alternative?
Thanks!
« Reply #4 on: November 25, 2019, 06:18:49 PM »
Thanks!
I don't think it's all that important what switch you use, as it is routed thru a relay. This is the switch mine has :
https://www.alliedelec.com/product/zf-electronics/rra32h3fbbnn/70207290/?gclid=EAIaIQobChMI_47z2OaG5gIVAr7ACh1WQwGtEAkYBCABEgLnD_D_BwE&gclsrc=aw.ds
The only real consideration would be one that fits the hole in the pod. Or one that you don't need to enlarge very much.
GRCTAMPA
Tampa, FL
« Reply #5 on: November 25, 2019, 07:20:28 PM »
Thanks!
Thanks, I will check that out.
SCain
Rio Rancho, NM
« Reply #6 on: November 26, 2019, 06:11:18 AM »
You might try a GL1800 switch, not sure it will fit.
https://electricalconnection.com/index.php/product/honda-gl1800-f6b-valkyrie-fog-light-switch/
I would just take your current switch apart and clean it, I had to do that to mine and it worked out fine.
Steve
Bagger John - #3785
« Reply #7 on: November 26, 2019, 12:50:21 PM »
I may have a new OEM one.
What I did with mine is to install a master cylinder switch block then replaced one of the switches to allow the lights to track the low beam, stay on all the time or be off.
Search this board for details. I've described the required parts a couple of times.
GRCTAMPA
Tampa, FL
« Reply #8 on: November 29, 2019, 04:34:40 PM »
Thanks everyone for the response. I wound up cleaning the switch and everything is working now.
Malkozaine
Lake County, Illinois
« Reply #9 on: December 27, 2019, 09:05:42 AM »
I just cleaned the switch on mine, still can't get the fog lights to stay on.  I assume the relay is bad?  Where is it located and where do I fine a replacement?
GRCTAMPA
Tampa, FL
« Reply #10 on: December 28, 2019, 03:50:10 PM »
See this post http://www.valkyrieforum.com/bbs/index.php/topic,81592.0.html
and this link for the original installation instructions http://valkyrienorway.com/download.html
