December 31, 2025, 03:18:21 AM *
Author Topic: 99 interstate fork seals  (Read 1359 times)
SpidyJ
Murrells Inlet
« on: December 24, 2019, 02:19:34 PM »
Anybody in the myrtle beach sc area that can do the job at a reasonable price?
Tried the red plastic shim thingy 3 times.  It stops leaking for a while but always starts again.
thx
johnny webb
1999 Fast Black Interstate
Peace,
johnnywebb
« Reply #1 on: December 25, 2019, 10:09:16 AM »
tricks I've used.
add some power steering stop leak to the fork fluid. I also pulled down the fork leg cap and wrapped the tube up against the seal with a piece of felt saturated with the stop leak and then reinstalled cap.
also I loosened the fork clamp one side at a time just enough to allow rotating the upper fork tube 180 degrees, re-tighten fork clamps to spec. both sides if both are leaking.
my forks haven't leaked since.
SpidyJ
Murrells Inlet
« Reply #2 on: December 25, 2019, 01:40:03 PM »
tricks I've used.
Wow......thanks for the tips.  Merry Christmas!
Peace,
johnnywebb
SpidyJ
Murrells Inlet
« Reply #3 on: January 06, 2020, 05:57:41 AM »
tricks I've used.
So I did the felt thing with the 180 degree tube rotation but I couldn't get the fork tube cap off.  It turned about 10 turns then just kept clicking and wouldn't unscrew any more.  What did I do wrong?
Is the lock nut holding it somehow?  Am I a Dingus or what?
Peace,
johnnywebb
SpidyJ
Murrells Inlet
« Reply #4 on: January 13, 2020, 10:54:15 AM »
So how do you get the fork cap off if you wanna add or check fluid? Embarrassed
Peace,
johnnywebb
« Reply #5 on: January 13, 2020, 11:19:37 AM »
you have to loosen the top clamp bolts, then the cap will loosen. check the manual, rods are connected to the caps.
do u have the manual?
download for free
http://valkyrienorway.com/download.html
turtle254
Livingston,Texas
« Reply #6 on: January 13, 2020, 12:54:25 PM »
tricks I've used.
You had it up on lift and rod was holding it down … lower the bike down slowly on the front wheel and watch the caps raise up off tubes. Never hold the rods down while you remove caps, just have a small amount of pressure on the front wheel, but not much or the cap will jump up hard.
SpidyJ
Murrells Inlet
« Reply #7 on: January 15, 2020, 06:55:48 AM »
Thanks fellas, I will try again if the fork leaks again.  For now....no leaks.
Peace,
johnnywebb
