November 20, 2025, 01:32:43 PM *
Author Topic: Knocking Noise when started in the Morning with this Cold Weather  (Read 1853 times)
valk2128
Suwanee, GA
« on: December 07, 2009, 03:30:13 PM »
My 1998 will make a knocking noise if I start it i the morning with no choke on in this cold 30's degree weather.  Never did this before.
I noticed if I put the chock on and then start it, I do not hear the knocing noise.
I use Amsoil Synthetic 10 x 30 oil with a Honda Filter.
Oil was changed about 500 miles ago.
Any ideas why it would knock when cold and no choke, and what should I do to eliminate this problem.
« Reply #1 on: December 07, 2009, 03:37:43 PM »
Use the firkin choke.
Think what you are hearing is it gasping for GAS.....
Steve K (IA)
Cedar Rapids, Iowa
« Reply #2 on: December 07, 2009, 04:16:12 PM »
I agree 100% with RJ.  Use the choke. cooldude  I have had roughly 11 Honda motorcycles and every one, including the 2 Valks I have now, have been cold blooded and I have had to use the choke on every one of them.  Even in the summer.  But, it seems if I start it again before it has completely cooled down, then the choke is not necessary.
States I Have Ridden In
Pete
« Reply #3 on: December 07, 2009, 05:08:46 PM »
Agree with both responders.
Without the choke in the cold conditions, 1 or more cylinders is not getting enough fuel to fire. That is why you are hearing the "knock". It is compression knock (without fire).
Thanks Pete.
« Reply #4 on: December 08, 2009, 08:10:43 AM »
Mostly because the RPM's are to low.
Got to keep that baby turning!
It's not a V-Twin you know.
