April 30, 2026, 12:40:17 PM *
Author Topic: Installed some rear saddlebag guards  (Read 4220 times)
bscrive
Ottawa, Ontario
« on: January 02, 2020, 05:15:01 AM »
I went and bought myself a set of black F6B rear saddlebag guards to see if I could install them on the Valk.  The ones on the F6B are installed horizontally, but there is nothing on the Valk to bolt them to, like that.
I took off the plastic cover and noticed that there is a place to bolt something to the frame.  You can see the hole in the top-center of the picture just below the fender.
I decided to put them on an angle and welded up some brackets to hold the one end and bolted it to the mounting spot under the plastic cover.
I connected the other side to the exhaust mount with a 1/4" spacer to keep the guard away from the exhaust.
I put the bags back on and they look pretty good.
They are on pretty good and will protect the bags if the bike falls over.  In a crash, well, I doubt much will stay on anyways.  It was a good project to keep me busy over the holidays and the guards were cheap.  I got them on eBay for $34.
« Last Edit: January 02, 2020, 05:18:19 AM by bscrive » Logged
« Reply #1 on: January 02, 2020, 08:00:55 AM »
Nice work.   cooldude
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #2 on: January 06, 2020, 04:49:58 PM »
Looking good.  cooldude
Farside
Let's get going!
S. GA - N. FL
« Reply #3 on: January 07, 2020, 03:31:02 PM »
 cooldude It does look good, nice job.  coolsmiley
Farside
« Reply #4 on: January 23, 2020, 03:55:10 AM »
You do nice work  cooldude
I was thinking about the same thing for my Corbin bags but found you dont need them. Just dont ask how I found out, bags never hit the ground with just the front guards holding the bike.   Grin
