December 31, 2025, 03:18:09 AM *
Author Topic: Preventing flat spots on tires and easy moving for winter.  (Read 1635 times)
dr.danh
« on: January 04, 2020, 07:01:41 AM »
Got the fat lady up on my jack and the E-bay mounted jack adapter for the winter. Was told would help prevent flat spots on tires from sitting a period of time. Also makes it handy for moving my bike around to have more space in the garage. Also will be handy for changing out the front tire while not riding season.
« Reply #1 on: January 04, 2020, 07:20:32 AM »
If you are going to leave it up on a jack for an extended time, make sure you use the emergency stops and some straps.
« Reply #2 on: January 04, 2020, 01:33:01 PM »
Flat spots from sitting take care of themselves with just a few miles down the road.
Gizmo
Ottawa Canada
« Reply #3 on: January 04, 2020, 01:37:12 PM »
And make sure the jack will survive the winter if it's sitting on the safety stop.
Nothing worse than a jack that gets stuck because you can't lift it to free the safety.
Been there once. That was enough.
Davemn
Minnetrista, Minnesota
« Reply #4 on: January 04, 2020, 02:40:06 PM »
I’ve never heard that modern tires get flat spots. Couldn’t you just move the bike every couple weeks?
Bone
« Reply #5 on: January 04, 2020, 02:50:08 PM »
The dealers park them on the tires. I make sure the pressure is correct.
What about the front and rear suspension whith the wheel weight hanging
during the storage.
« Reply #6 on: January 04, 2020, 03:32:26 PM »
What about the front and rear suspension with the wheel weight hanging
during the storage.
That's the issue that I see, especially with 20yo suspension.  I like the idea of jacking up, but just so the tires still touch, but not completely unloading the suspension.  If the safety notch on your jack is not available at that low height, just do what Mike does and stick a 2 X 4 through the jack scissors and let it down on that.
My two interstates sit on the side stands most of the winter, with a few short runs.  I've never had flat spots, but boy I've had cold slippery tires.
« Reply #7 on: January 05, 2020, 10:08:15 AM »
My bike sits on its tires unmoved for five months every year.  No problem with flat spots.
« Reply #8 on: January 05, 2020, 10:24:59 AM »
Same here.
« Reply #9 on: January 05, 2020, 07:03:38 PM »
Concrete can absorb moisture over a period of time. I've heard of putting cardboard or carpet under the tires when being stored for a long time.
« Reply #10 on: January 06, 2020, 05:57:46 AM »
Just bring your bike to me here in Florida and I’ll ride it every few days all winter for you. Then you will have even more room in the garage.  crazy2
Relax
Power & elegance...just like the Valk
Oslo, Norway
« Reply #11 on: January 06, 2020, 06:01:40 AM »
What a terrible place to live! uglystupid2 Y
How do you bear living with riding weather all year???
dr.danh
« Reply #12 on: January 06, 2020, 07:00:13 AM »
Yeah my jack has the loops for straps. So do that for any period of time stored. Going to put a new tire on frt. and may pull the rear and regrease while up. Ccar tire extends the regrease spline time above 10k.
https://www.ebay.com/itm/LOOK-VALKYRIE-HONDA-JACK-LIFT-ADAPTER-1-BEST-MOTORCYCLE-ITEM-Save/181170677159?hash=item2a2e9d25a7:g:R9wAAOSwu4BVsCA7
mbramley
Painesville Ohio
« Reply #13 on: January 06, 2020, 07:15:34 AM »
 If you get people on board with this Idea let me know and I will move to Florida (probably will anyway) and assist in the road pampering of Valks.
BigM
« Reply #14 on: January 09, 2020, 01:15:28 PM »
I was curious why I had heard that. Makes since that the concrete holds moisture. Noticed some dealers do park the tires on carpet pads. May be just not to mark the floors up. I have the m/c jack and adapter mentioned. Works great for me.  cooldude
CoreyP
Bluffton, SC
« Reply #15 on: January 09, 2020, 09:15:43 PM »
No not in my Valkyrie's case. I rode a 1,000 miles after I bought it. I didn't baby it either.  The flat spot on the front tire didn't go away. The bike didn't get ridden much in 3 years before I bought it but in the end both tires were crap. In my case the tires were old as well, tread was fine but too old and the bike had sat for a while.
BTW brand new Avon's are much better than what was on the bike. I'm kind of glad I gave the old tires a run before I replaced them. Hard to explain, the bike felt pretty good but with new tires, it smoothed right out. I'm liking my Valkyrie.
