December 31, 2025, 03:17:02 AM
crankshaft pulse rotor -004
Topic: crankshaft pulse rotor -004 (Read 1222 times)
blacktrain
douglas,ma
January 12, 2020, 01:47:54 PM »
hi,i just got a box of valk parts from a friend and found a pulse rotor marked 004 , would this be a stock item or to advance the timming. this goes between the belt gears, any info would be great
blacktrain
douglas,ma
Re: crankshaft pulse rotor -004
January 12, 2020, 04:32:33 PM »
sorry thats on my 1997 valk ct,thx
January 12, 2020, 06:55:15 PM »
That's called a trigger wheel. The 004 is 4 degree advancement. Most wheels are 6 deg. The Valk Interstate advances the mid range timing 2 degrees so the 004 wheel is used on interstates. BUT it can also be used on a standard/tourer too.
blacktrain
douglas,ma
January 15, 2020, 03:36:45 PM »
thanks sandy, so this would advance my timing 4 deg ,is that correct. if thats the case it may be worth the time to install it. thanks
January 17, 2020, 10:04:28 AM »
Yes; 4 degrees. It MIGHT cause you to need mid grade fuel or premium, but I doubt it.
blacktrain
douglas,ma
January 19, 2020, 05:01:37 PM »
great thanks , have to add that to my winter service list of things to do,
=> InZane XXV
