December 31, 2025, 03:18:27 AM *
Author Topic: Carburettor heater hoses to prevent carb icing - are they needed?  (Read 1589 times)
wirral_biker
Wirral, ENGLAND
« on: January 15, 2020, 12:21:01 PM »
][url=https://flic.kr/p/2iftiq6]IMG_1911 by KC, on Flickr[/url]
Not sure if the photo will be shown on here...but took the carbs off today on my May 1997 UK spec F6C, just for a clean and found that they have hot water from radiator running past them ( through those black hoses but they don't actually connect through the carbs themselves, just simply run underneath as a sort of carb icing heater.          These are summer bikes in the UK so was wondering if those hoses could be removed?
« Last Edit: January 15, 2020, 12:30:27 PM by wirral_biker » Logged
I will never learn, on my 4th Valkyrie now !
« Reply #1 on: January 15, 2020, 02:08:29 PM »
No radiator heating involved. The long black hoses are simply vents that plug into the two hole brace. The short tubes between the carbs are for fuel. Only other tubes are for draining the carbs.
« Reply #2 on: January 15, 2020, 02:13:40 PM »
John, I think his are different. Mine don’t have those. I think I remember Leathel talking about that on his New Zealand model. Along with a different idle screw setup. Also, I think those models have a much smaller main jet.
 I would suspect they are not so much for deicing, but for emission control.
wirral_biker
Wirral, ENGLAND
« Reply #3 on: January 15, 2020, 04:40:14 PM »
Well they connect to the radiator and were full of anti freeze  Grin
I don't think they are emission, just warmth for the carbs etc.
It is true about the mixture screws on mine as being 1 3/4 turns out ( just for the 1997 year ONLY ).
I'll be starting her up tomorrow ( have to first submit to a dentist in the morning Embarrassed ) just to check for leaks etc.
Leathel
New Zealand
« Reply #4 on: January 15, 2020, 05:54:24 PM »
I removed mine, had them on my UK sold Valk (imported to NZ from the previous owner)  not controlled from memory so heating year round and warm fuel = loss of power
« Last Edit: January 15, 2020, 06:10:47 PM by Leathel » Logged
Leathel
New Zealand
« Reply #5 on: January 15, 2020, 05:57:12 PM »
was yours the UK model? Smaller pigs tails, Extra foam in the air cleaner, 78 main jets, TPS on the back of the RH side
« Reply #6 on: January 15, 2020, 06:22:55 PM »
actually, if set up right, heated could be more power not less.  heated fuel will vaporize quicker and better.
« Reply #7 on: January 15, 2020, 06:37:56 PM »
Well there ya go, I learned something about the UK bikes. Can't imagine why it's needed but so be it!  cooldude
Ken aka Oil Burner
Mendon, MA
« Reply #8 on: January 15, 2020, 08:10:08 PM »
Don't know why either. I've ridden in temps well below freezing a few times; even on the highway. Never had any freezing issues. I know it's possible, but why on UK spec bikes and not USA spec bikes? It gets cold here too.
steveB (VRCC UK)
« Reply #9 on: January 16, 2020, 03:45:14 AM »
Well it's not cold and salty here in my part of the UK its very wet and mild (12C). Anyhow took a stroll to my workshop to check my own Valks as I seem to have worked on Valks with and without carb heaters. My 98 does not have carb heaters so no cut out in the left side radiator cover. My 2000 has carb heaters with a cut out in rad cover to the extra outlet in the rad. Both bikes are Euro spec sold new in the UK.
Strangely both have the same jetting and pre-filter air boxes and both ride exactly the same. I see no problem in removing the heaters and blocking the outlets but why?
Check your VIN no on Dags Valk geneology site www.valkyrienorway.com/Valkyrie%20Genealogy.html and it's probable that yours is a Scandinavian model. My 2002 (fast black) was supplied through the Belgium distibutor to my local dealer and the VIN plate indicates it was specced for Sweden (a very much colder clime). I've never noticed any difference between early and later models even in freezing weather.
My own feeling - as the Euro models have smaller pilot and main jets than the USA models the heaters are there to aid enrichment (warming up) not carb icing as such. (I thought it was usual to warm manifolds to prevent icing).
wirral_biker
Wirral, ENGLAND
« Reply #10 on: January 16, 2020, 04:29:42 AM »
I'll be starting her up tomorrow ( have to first submit to a dentist in the morning Embarrassed ) just to check for leaks etc. as the piping covers one of the float bowl screws on each carb!!
Yes, exactly as described, one of the first UK models.   I couldn't get the small ( hex ) bolts out to release the water pipes and get the float bowls off!
« Last Edit: January 16, 2020, 04:32:13 AM by wirral_biker » Logged
WintrSol
Florissant, MO
« Reply #11 on: January 16, 2020, 08:41:38 AM »
If you really want to know why you heat the carbs, the answer lies in what my FIL explained to me; he was a long-time engineer at the Carter Carburetor company. It seems that when the fuel is atomized into a fine mist, there is a large temperature drop, especially as the velocity in the venturi approaches the speed of sound. This high velocity works for you, in that the fuel is broken into ever finer droplets, which create the best combustion. The temperature drop works against you, as the colder the mist, the more it wants to condense into rain, which is bad for combustion. So, if you heat the fuel a bit, or keep the venturi warm, condensation is less likely to occur. In autos, the manifold was often heated, to keep the mist from forming 'dew', and just dripping into the cylinders, but we don't have a manifold. Thing is, if you heat it too much, the fine droplets in the mist turn into vapor, which also doesn't burn as well in an engine, so you have to balance the amount of heat against the temperature drop; in colder climates, this works well, but nearer the equator, not so much.
Leathel
New Zealand
« Reply #12 on: January 16, 2020, 09:58:32 AM »
The hex screws have countersunk heads and are quite long, plenty of room to drill the heads off and use vice grips to remove the shaft of the screw when the pipe is off,  you don't need the screws after its removed the thread hole doesn't go through the body. I have removed the restrictive pigtails & foam on the air filter and put 100 mains in and it goes much better. If replacing the jets check the float levels as the plastic floats are old and if distorted can cause hydroloc Wink
« Reply #13 on: January 16, 2020, 10:04:48 AM »
it is the vapor that burns and not the mist, you put that backwards.
wirral_biker
Wirral, ENGLAND
« Reply #14 on: January 16, 2020, 10:30:29 AM »
[/quote]
[/quote]
Worth knowing as I may remove those 'heater' hoses next time I have to remove the carbs.  Fired her up this morning and she runs nicely...just a very small crackle now and again, so after a healthy ride to see how she runs, I may back out the mixture screws to 2.0 turns and check again etc.
WintrSol
Florissant, MO
« Reply #15 on: January 16, 2020, 10:46:22 AM »
Actually, the mist presents a better flame front, as it turns to vapor in a more-controlled fashion. If only vapor is introduced, you often get knock or uneven burn. At least, that's what an expert in carburetion told me. This is probably why direct injection is the current darling of engine designers.
« Last Edit: January 16, 2020, 10:57:01 AM by WintrSol » Logged
wirral_biker
Wirral, ENGLAND
« Reply #16 on: January 17, 2020, 05:20:51 AM »
[/quote]
[/quote]
[/quote]
Hi leathel,
Great details/advice.  I am assuming you left the 'heater' hose off the carbs and simply bye passed from one side of the radiator to the other with some hosing?
Cheers
Leathel
New Zealand
« Reply #17 on: January 17, 2020, 11:16:02 AM »
[/quote]
[/quote]
Hi leathel,
Cheers
[/quote]
 I had to go and look it was so long ago that I did mine, Yes left them off but no I just capped the pipes to stop the flow Smiley
