December 31, 2025, 03:17:03 AM *
Author Topic: Antifreeze dripping from #2 exhaust pipe  (Read 1297 times)
recman25
Tucson, AZ
« on: January 19, 2020, 02:50:33 PM »
Just finished a ride the other day when on the next morning I saw a small puddle of antifreze under the bike. Upon closer inspection, it seems its coming from around the #2 cylinder exhaust studs that bolt the exhaust pipes to the block. The bolts/ nuts were a little loose, so I gave them about a 3/4 turn. Hopefully that was it, but any suggestions would be appreciated! By the way, its not blowing any white smoke/ steam and the oil doesnt seem to have any water mixed in
Dan
  1999 Valkyrie Interstate
  Tucson, AZ  formerly Jersey Shore
pancho
Bonanza Arkansas
« Reply #1 on: January 19, 2020, 04:03:26 PM »
It may be dripping from the exhaust studs, but is probably coming from elsewhere.  Check the water pump, thermostat housing and radiator hoses for the leak.
« Reply #2 on: January 19, 2020, 04:50:56 PM »
Most likely o-ring leakage on the metal tubes. If you look down in the valley of the engine you'll probably see a little anti freeze puddled there also.
Forge
San Antonio, TX
« Reply #3 on: January 19, 2020, 05:04:45 PM »
I had the same thing happen and was worried I may have cracked a head. Looking higher up, I saw it dripping from around the hose at the thermostat housing on top of the engine behind the radiator. I snugged that clamp up and no more leak! I had to drain the coolant and slip the hose off the upper right hand radiator extension. That was a bitch. Then I loosened the top mount and rotated the radiator enough forward that I was able to get a long quarter inch extension with a universal swivel and socket and tighten the clamp up.
« Reply #4 on: January 19, 2020, 05:13:17 PM »
Tight hose clamps are good.
But a lot of times, after a bike sits in the cold for awhile, it will leak from a hose a bit on startup/heatup, but then everything expands back to normal and no more leak.  Until the next time it gets frozen.
You check your reservoir, that may not look like you lost much or any coolant.
« Reply #5 on: January 19, 2020, 05:25:36 PM »
Top radiator hose clamp tighten it and your leak will disappear.
« Reply #6 on: January 20, 2020, 06:47:06 AM »
“Hopefully that was it” really?
If coolant is in the combustion chamber you would have much more serious problems.
As was said it’s leaking up higher and dripping down.
recman25
Tucson, AZ
« Reply #7 on: January 20, 2020, 07:14:55 AM »
I must have misspoke. That was my fear! But there's no water in crankcase and no oil in cooling system.  No steam blowing out of exhaust. Will be tightening hoses later today
Dan
Large
« Reply #8 on: January 20, 2020, 04:29:53 PM »
Had this same issue last year check the thermostat hose clamp
