April 30, 2026, 12:40:25 PM *
Author Topic: Corbin seat mount  (Read 3457 times)
Jack B
Two Rivers Wis
« on: January 22, 2020, 02:19:18 PM »
I bought a used Corbin Gunfighter seat and it looks like new.
The question I have is when I mount it the rear was about an inch higher then the fender.
I pushed it down and put the bolts in and it all looks great but Boy! it's a tight fit and you could hear some binding.
(Yes the front tab was in the mount)
Is that the way the seats fit?
Let’s RIDE
« Reply #1 on: January 22, 2020, 04:00:24 PM »
Mine fit right on... I have the other kind though...
Jack B
Two Rivers Wis
« Reply #2 on: January 22, 2020, 06:56:34 PM »
Here's a picture before it's bolted down
Here it is after it's bolted down. It looks good it's just that it made some funny noises going down.
I'm hoping that's it's fine, but it's binding somewhere, once it's warmer out then I can look at a lot better.
Let’s RIDE
« Reply #3 on: January 23, 2020, 03:43:37 AM »
I have the same dual tour and it had to be pushed at the rear a bit, but if I repositioned it a bit or made sure the rubber bumpers on the bottom were positioned a little differently it seemed to fit better. What you have in the pictures does not seem that bad though. Sometimes by hooking the seat in the front and sliding it back and forth a bit it seemed to position better at times.
« Last Edit: January 23, 2020, 03:45:28 AM by Robert » Logged
