December 31, 2025, 03:18:16 AM *
Author Topic: Valkyrie interstate brake pads part number  (Read 1232 times)
Savago
Brentwood - CA
« on: January 30, 2020, 04:49:25 PM »
Gentlemen
My I/S@1999 needs some new front brake pads and looking into partzilla (https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500cf-a-valkyrie-interstate/front-brake-caliper), it is listed with 2 part number codes:
a) 06455-MV4-405: https://www.partzilla.com/product/honda/06455-MV4-405
b)  06455-MZ0-760: https://www.partzilla.com/product/honda/06455-MZ0-760
Do I need 1 of each?
While at it, how hard of a job is it to replace the pads?
Best regards
Savago
« Reply #1 on: January 30, 2020, 05:13:11 PM »
I'm not sure why they have 2 different numbers. Sometimes Honda changes them, but they will usually show the old number as not available. You need 2 sets. You can find them much cheaper though. I think I get both fronts and a rear for about $40 total. If you've changed pads on a car, you can easily do it on your bike.
Savago
Brentwood - CA
« Reply #2 on: January 30, 2020, 06:15:42 PM »
@meathead: do you mean that probably they are the same/similar part, but only with 2 different part numbers?
If so, would buying 2x of a single (either 'a' or 'b') would be enough?
« Reply #3 on: January 30, 2020, 06:50:18 PM »
Yes, I believe so. Although I suspect one number might be discontinued. If so, you might be delayed in getting them. If you are set on OEM, I'd cross check with another parts company and see what they list.
« Reply #4 on: January 30, 2020, 08:05:14 PM »
I believe Honda updates the numbers for whatever reason and the parts companies leave the originals up, probably for cross reference.
I've ordered parts using the original numbers and the parts company has changed them to the new numbers automatically.
« Reply #5 on: January 30, 2020, 08:12:58 PM »
http://www.valkyrieriders.com/shoptalk/bongopads.htm
Not hard, but does take some skill and knowledge.
Savago
Brentwood - CA
« Reply #6 on: January 30, 2020, 08:29:30 PM »
This seems to be a full set and goes for 29.99 + free shipping:
https://www.amazon.com/Zinger-2013-2015-Suzuki-2012-2014-Replacement/dp/B07VXG1LXX/ref=sr_1_2?keywords=06455-MZ0-760&qid=1580444878&sr=8-2
What you guys say?
ridingron
Orlando
« Reply #7 on: January 30, 2020, 08:40:29 PM »
The parts fish I order parts from also has the 2 numbers listed. However, the ....760 number is crossed through and the ....405 number is listed.
item #2
https://www.partsfish.com/oemparts/a/hon/506c2f6ff870023420a31b53/front-brake-caliper
« Reply #8 on: January 30, 2020, 08:47:01 PM »
My opinion is to stay with OEM.
« Reply #9 on: January 30, 2020, 08:51:23 PM »
Those might be correct, but they don't list the Valkyrie as fitting them. Which would make me hesitate. I'm sure some will speak up about using cheap pads. I've been using them for many, many miles with zero issues.
https://www.amazon.com/dp/B078QYWD21/ref=psdc_404700011_t2_B078R32N1P
« Reply #10 on: January 30, 2020, 10:12:28 PM »
When considering cheaper (and non OE) brake pads, check the prices on new rotors.
« Reply #11 on: January 31, 2020, 04:43:15 AM »
Organic material pads should be used. There is no extra wear with them.
Savago
Brentwood - CA
« Reply #12 on: February 04, 2020, 12:14:07 PM »
item #2
Received a msg from partzilla saying that, indeed, 760 was superseded by 405.
