BINOVC
« on: February 15, 2020, 01:39:30 PM » |
I'm thinking about replacing the float bowl and slide cover screws with stainless steel socket head screws. The parts fiche lists the diameter and length but not the thread pitch: Float chamber: 5x16 Slide cover: 4x18 It looks like the M5 screws are available in .5 (fine) and .8 (coarse). The M4's are either .5 (fine) or .7 (coarse). Anyone know the pitch? Thanks!
« Last Edit: February 15, 2020, 02:09:47 PM by BINOVC »
« Reply #1 on: February 15, 2020, 04:58:01 PM » |
I understand this won't change your mind, but I'm going to tell you this anyways so you know.
The carburetor float bowl screws are a very special screw that Honda, in their wisdom, makes just for the float bowls.
The screws are made of an especially soft metal composition so that, in a case of over tightening the screw, the screw will strip
and not the threads in the carburetor body which holds the float bowl.
It's a very expensive proposition to replace the carburetor body.
The little screws are cheap when compared.
« Reply #2 on: February 15, 2020, 06:21:48 PM » |
 when did steel screws become softer than aluminum carburetors ?
steveB (VRCC UK)
« Reply #3 on: February 17, 2020, 12:43:50 PM » |
I've used them on carb rebuilds and they give a nice tidy look. Take on board what Ricky-D says and don't brute them up, just snug. Used M4 x 0.7 & M5 x 0.8 suggest you try for size and use copper grease.
« Last Edit: February 17, 2020, 01:01:30 PM by steveB (VRCC UK) »
WintrSol
« Reply #4 on: February 17, 2020, 01:57:03 PM » |
 when did steel screws become softer than aluminum carburetors ? One of the reasons people think Honda's screws are too soft is they use a Phillip's screwdriver, and bugger the heads. I've never damaged one using the proper 'JIS' type screwdriver in them. I'd never heard the screws were softer than aluminum before.
98 Honda Valkyrie GL1500CT Tourer Photo of my FIL Jack, in honor of his WWII service
« Reply #5 on: February 17, 2020, 02:28:47 PM » |
0.8 thd
BINOVC
« Reply #6 on: February 17, 2020, 08:35:21 PM » |
Thanks all. Note I read (on McMaster-Carr website) says that if the pitch is not stated, then it is most likely a coarse thread (M5x.8, M4x.7).
6adan
« Reply #7 on: February 18, 2020, 11:52:00 AM » |
For anyone that has striped threads there is a product called a Time-Sert that works great for repairing the carbs.
1970 CB750JDM, 1975 GL1000, 1979 GL1000 semi cafe, 1979 CBX, 1995 GL1500 SE, 2008 GL1800 trike. Several more not running yet.
h13man
Indiana NW Central Flatlands
« Reply #8 on: February 22, 2020, 06:48:55 AM » |
A excellent insert for sure given you have wall thickness to use them thus HeliCoil come into play but not my favorite to use. You can also make a insert out of a set screw using Loctite to keep in place or "staking" it in similar to the Time-Sert method.
