November 13, 2025, 08:46:05 AM
Frustrating start to the season
Topic: Frustrating start to the season (Read 1466 times)
DGS65
Time enjoy wasted is not wasted time
Nanuet, NY
March 07, 2020, 02:12:46 PM »
Today I went to pickup my bike from storage at my in laws. It was a little hard to start then once started it ran rough for a bit. I wasn't too concerned being I had run it dry at the end of the season as it started to smooth out my wife came over and notice there was a very steady drip maybe light stream of fuel. It was very hard to see were the leak was coming from but again the bike sat dry so I assumed the floats were stuck, I tried tapping the bowls it seemed to slow up a bit but not stop completely. Being the bike was now running Pretty well I decided to drive it home were I can further work on it with tools at my disposal. When I got it home I poured whatever seafoam I had in the tank and began looking closer, I found one of the hose lines from the carbs loose and fuel was dripping once reconnected the leak appears to have stopped. I'm hoping this is all it was but I suspect it was part of a bigger problem.
Re: Frustrating start to the season
March 07, 2020, 03:58:23 PM »
What “hose line” are you referring to?
DGS65
Nanuet, NY
March 07, 2020, 05:29:31 PM »
Oddly the drain hose which would mean one of the other carbs is draining and backing up into the another but why didn't it drain out the bottom?
March 07, 2020, 07:18:45 PM »
Sounds like fuel rail o-rings to me.
March 08, 2020, 06:41:26 AM »
Let the o rings swell a little now that they are in contact with fuel. Check it in a day or 2.
9Ball
March 08, 2020, 06:36:12 PM »
Quote from: meathead on March 07, 2020, 07:18:45 PM
Agreed...
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
DGS65
Nanuet, NY
Reply #6 on:
March 21, 2020, 07:59:53 PM »
Update as many suspected it was likely the Orings which seem to have corrected themselves once the swelled.
I had time to let the bike run in my driveway for a bit with seafoam in the tank. I'm happy to say everything is working properly and the bike is running great. I took it for a short ride and it runs like a charm plenty of power to get up and go!
=> InZane XXV
