June 24, 2025, 12:43:13 AM *
Author Topic: After desmog, no spark to cylinders 1& 2... UPDATE/Resolved  (Read 953 times)
PSUbag
Huntingdon, Pa.
« on: March 08, 2020, 12:21:06 PM »
Did I possibly knock a wire connection loose or something when installing the airbox? Anyone know where to start looking? Bike was running great before the desmog.   Undecided
« Last Edit: March 08, 2020, 04:00:08 PM by PSUbag » Logged
wirral_biker
Wirral, ENGLAND
« Reply #1 on: March 08, 2020, 01:21:30 PM »
Tank off and back track to the coil....probably be a low tension wire connection/break.
I will never learn, on my 4th Valkyrie now !
« Reply #2 on: March 08, 2020, 01:44:47 PM »
#1 & 2 are the two front cylinders(right/left sides respectively) and as I recall are fed/fired by the front coil mounted on the left frame member under the tank. Loosen the tank and lift just enough to see if you knocked a wire off that coil.
PSUbag
Huntingdon, Pa.
« Reply #3 on: March 08, 2020, 04:02:06 PM »
Sure enough, I must of bumped the rear wire off of the coil. This website is the best. She is running like new again! Grin
