December 31, 2025, 03:18:21 AM *
Author Topic: SS Brake Lines and Clutch Line Yes or No  (Read 1371 times)
Calboy
« on: March 09, 2020, 01:50:34 PM »
How many of you have replaced the OEM brake and clutch lines with the SS lines (Galfer)?
Do you find it to be a noticeable improvement? And I'm referring to the Valkyrie in particular.
Once again, I'm not talking about any experience with any other other bike but the Valkyrie.
« Last Edit: March 09, 2020, 01:55:45 PM by Calboy » Logged
WintrSol
Florissant, MO
« Reply #1 on: March 09, 2020, 02:18:23 PM »
The brake lines do make a subtle, but noticeable improvement. The stock brake lines can balloon a little, taking up some of the pressure; this gets worse with age. Some like that cushioning effect; I like the more precise feel. I have the clutch line, but haven't installed it yet; not sure it will change the feel as much, just because the line never gets hard the way brakes do.
Disco
Republic of Texas
« Reply #2 on: March 09, 2020, 06:02:10 PM »
Yes.   coolsmiley
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: March 10, 2020, 07:08:09 AM »
Well hashed out here: http://www.valkyrieforum.com/bbs/index.php/topic,19915.0.html
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #4 on: March 10, 2020, 06:12:28 PM »
Yes.  I have the brake lines installed, need to have the clutch line slapped on.   For me pretty big noticeable difference over stock.
« Last Edit: March 10, 2020, 06:14:01 PM by Valkorado » Logged
CoreyP
Bluffton, SC
« Reply #5 on: March 10, 2020, 09:23:06 PM »
Honestly unless you are riding a sport bike balls to the walls you won't see a difference. Are they safer? Yes. Look nice? Yes. Will you notice a difference on a Valkyrie? No. You will probably feel a difference because you think it should feel different so why not.
Calboy
« Reply #6 on: March 12, 2020, 11:41:40 PM »
I feel exactly the same way you do but I was curious about other people's take on the subject.
And that's why I asked opinions on the Valkyrie alone and no other motorcycle.
Thank you all for your input.
Jersey
VRCC #37540
Southern Maryland
« Reply #7 on: March 13, 2020, 05:18:05 AM »
In my experience, an aged rubber line will cause the brakes to lock up due to the rebounding of the rubber hose.  An aged hose will expand slightly on initial braking and then rebound a little, thus causing an increase in hydraulic press.  When you're braking with higher pressure... being on the fringe of locking up the brakes... this rebound will put it over the edge and suddenly lock things up.  That's just my experience, others may have something different.
SS lines help prevent/reduce this, so what you're squeezing is what will occur.
Hope that helps.
Jersey
