December 30, 2025, 11:36:44 PM *
Author Topic: Normal Force Needed for Clutch Lever  (Read 2158 times)
Coot
« on: March 13, 2020, 11:46:31 AM »
Is it normal for the clutch lever to require heavy force to pull? Compared to other motorcycles that I have owned, my '99 IS requires much more effort to pull.  Thoughts, please.  Thanks, Coot
Warlock
Magnolia, Ms
« Reply #1 on: March 13, 2020, 01:11:08 PM »
I saw a thread on facebook where a guy used a VTX 1800 master cylinder on a Valkyrie instead of the Valkyrie and it made a much easier pull. Can't verify it other than if you read it on the net its got to be true.
David
Coot
« Reply #2 on: March 13, 2020, 01:27:06 PM »
Thanks for the reply. So does that mean that the hard pull is normal?
da prez
Wilmot Wi
« Reply #3 on: March 13, 2020, 04:48:50 PM »
Lube the pivot pin after checking the bushing for wear. Basic maintenance.  It should solve the problem .
       da prez
« Reply #4 on: March 13, 2020, 05:49:17 PM »
hard pull is not normal
Coot
« Reply #5 on: March 13, 2020, 07:00:53 PM »
       da prez
Many thanks.
Bone
« Reply #6 on: March 14, 2020, 08:49:01 AM »
No,  mine is the only Valk I have rode so my experience is limited to 1 bike with 160K miles.
rug_burn
Brea, CA
« Reply #7 on: March 14, 2020, 09:39:19 AM »
I agree with some of the others, that definitely is not normal.    You want to check that out right away.
   From my own experience, that happened to me once (in a car) and it was because the throwout bearing (which moved in and out in a machined bore,)  got crooked and jammed, eventually messing up that bore it ran in.  A Valk's configuration could be similar, as I recall.
...insert hip saying here..
« Reply #8 on: March 14, 2020, 02:29:16 PM »
      99 I/S with over 125G on the clock and when the clutch started needing more effort to pull the lever I figured out with the help of this board that it was the bushing. Lubed both levers-brake and clutch-while I waited on new bushings and new Kury wide levers. All good now. Remember to lube those bushings maybe on every or every other rear end lube-approx. 10000 miles or so. RIDE SAFE.
9Ball
« Reply #9 on: March 15, 2020, 03:29:21 AM »
Also, maybe a good flush of fluid is needed.  They do make a master cylinder rebuild kit that may improve the extra force/resistance that you are experiencing.
I flush mine at least every two years and occasionally every year when I have extra synpower leftover from flushing the other two bike’s brake fluids.  Once the seal is broken I dispose any extra brake fluid since it is hygroscopic.  I used to buy the Valvoline synpower in quart bottles, but now I buy several pints at a time to minimize wasting of any leftover fluid.
Let us know how you make out.  Good luck...
« Last Edit: March 15, 2020, 03:35:54 AM by 9Ball » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Coot
« Reply #10 on: March 15, 2020, 06:25:02 AM »
Many thanks to All of You for taking your time to help me.  Coot
Paladin528
« Reply #11 on: March 17, 2020, 07:38:01 AM »
I have a barnett clutch with heavy duty spring.  it is HARD to pull.  sucks in traffic.
quexpress
Montreal, Québec, Canada
« Reply #12 on: March 23, 2020, 11:06:13 AM »
David
http://www.valkyrieforum.com/bbs/index.php/topic,80708.msg800499.html#msg800499
I did that mod in Sept 2015.  cooldude
I still have a full deck.
I just shuffle slower ...
h13man
Indiana NW Central Flatlands
« Reply #13 on: March 23, 2020, 11:42:16 AM »
Parts search shows all VTX 1800's use the same master cylinder. Found a couple used ones on Ebay $27 shipped. $33 for OEM rebuild kit vs $126 new for complete master cylinder. Mines has been always a hard pull. I just figured it was the norm even with routine maintenance all my 30,000 mi. of ownership. Hmmmm.
Warlock
Magnolia, Ms
« Reply #14 on: March 23, 2020, 11:44:13 AM »
David
[/qu
Thanks for verifying that it is a solution for the hard pull.
David
Warlock
Magnolia, Ms
« Reply #15 on: March 23, 2020, 12:00:26 PM »
David
Was wondering can you use the same clutch lever or have to use a VTX clutch lever.
David
quexpress
« Reply #16 on: March 23, 2020, 01:06:20 PM »
David
David
You can use the same clutch lever David ... unless my old memory is playing tricks on me.  Smiley
« Reply #17 on: March 23, 2020, 01:35:07 PM »
There's a bunch more in the clutch lever than I imagined before I did maintenance
on mine... what got me to do it was that the lever was floppy in the perch and
Gordon just couldn't have that  Wink ...
There's two bushings, one (the big one) is pressed into the OEM lever, and the
other one is a separate part... and the rubber seal that snaps onto the push rod...
Here's a shot of a grungy old eBay clutch master cylinder with all that pulled out.
Anwho... I have a new OEM lever (which comes with the new big bushing) and
a new small bushing and a new rubber seal and a little bit of that blue belray
grease down in there where the push rod pushes on the master cylinder piston,
my clutch lever action is really fine now  cooldude
https://www.partzilla.com/catalog/honda/motorcycle/1997/gl1500ct-a-valkyrie-tourer/clutch-master-cylinder
There's, like, another clutch cylinder down where you bleed the clutch,
I've never messed with that (other than to bleed)...
https://www.partzilla.com/catalog/honda/motorcycle/1997/gl1500ct-a-valkyrie-tourer/clutch-cover
Like everyone sez, your clutch action should be good, so if it is not
you should look for a problem... hopefully you don't look look look until
you find out someone put in a barnett clutch in there and it is supposed
to be stiff...
Coot
« Reply #18 on: March 24, 2020, 05:40:05 AM »
Many thanks for the helpful tips from all of you:)  Coot
