December 31, 2025, 03:17:13 AM *
Author Topic: Battery connectors - KnuKonceptz  (Read 1622 times)
« on: March 15, 2020, 12:12:26 PM »
I was down some rabbit holes on youtube, and came across this video,
https://www.youtube.com/watch?v=F2a8Seirw94
then the company, http://www.knukonceptz.com/mobile-audio/battery-terminals/
I've been adding items to my battery, and to make the connections easier, I added 2 lengths of wire (1 pos & 1 neg) so I could easily add/remove connections, and then only have one connection onto the battery, for winter storage disconnect. Along with the rubber covers cracking (available from marinas), these terminals give multiple screw connectors and new covers, for not much more than the cost of covers here.
Add a battery post connection and a new connector, I'm thinking the Bassik, and now everything is up at the battery, instead of moved over to where the tool kit is stored in the battery compartment.
This may also be something nice for those adding a remote fuse box. Add another lead to the connector, running to the new fuse box.
Enjoy
mello dude
Dayton Ohio
« Reply #1 on: March 15, 2020, 02:53:25 PM »
Hey - thanks! - - -  thats some nice connections to the battery. Good stuff  cooldude
« Reply #2 on: March 15, 2020, 05:08:35 PM »
MC connections?
« Reply #3 on: March 16, 2020, 10:36:20 AM »
MC connections?
Yes, I have the same question. Didn't see any m/c application which I'd love to have, sure would clean up what I now have hidden under the cover.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #4 on: March 16, 2020, 10:46:45 AM »
Hard to beat a good terminal strip.
So many roads, so little time
VRCC # 5258
Grandpot
Fort Mill, South Carolina
« Reply #5 on: March 17, 2020, 06:23:15 AM »
It's a good idea as long as there is  enough room around the battery.
Paladin528
« Reply #6 on: March 17, 2020, 07:36:01 AM »
eastern beaver makes a great fuse box / terminal connection
« Reply #7 on: March 17, 2020, 09:03:01 PM »
MC connections?
No, not MC specific. I figure you can screw in the terminal post, then use that clamp on. If the post nut is the wrong thread, just change out the nut, I don't know if it would fit. I would email KnuKoncept before ordering.
They do make a good one, and others brands too, with nice options.
I bought a used set of the positive/negative battery cables, and I used them as extensions for mounting all the extra items that have been added to the battery, with a nut/bolt/cover to hold them on. This way I only have 2 leads on each screw, when it comes time to remove them from the battery. Those leads already have built in fuses, and I did find my external additional fuse box, which I intended to add a relay too and move all my additions to.
Pappy!
Central Florida - Eustis
« Reply #8 on: March 18, 2020, 07:00:04 PM »
This might be a better option for you. These were specifically built for the Motobatt batteries but I do believe they will fit pretty much anything out there.
I bought a motobatt battery (AGM) recently. It has a total of (4) battery terminals on it but the Motobatt supplied terminal adapters are, in my opinion, junk.
Lamonster came up with some pretty nice ones!
http://www.lamonstergarage.com/motto-battery-block-set-motorcycle-lamonster/
« Reply #9 on: March 19, 2020, 02:40:46 PM »
I have this on my bike
http://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html
psckam
Elmira, New York
« Reply #10 on: March 19, 2020, 04:27:40 PM »
thats pretty nice looking and a clean setup kinda exspensive though
« Last Edit: March 19, 2020, 04:29:35 PM by psckam » Logged
