November 13, 2025, 08:45:41 AM
Ignition on wire
Topic: Ignition on wire (Read 1217 times)
Whitey
Ignition on wire
March 18, 2020, 02:05:04 PM »
Hey guys just wondering if any of you have ever spliced into the ignition on wire for a accessory? If so have you had any problems? Thanks!
da prez
Wilmot Wi
Re: Ignition on wire
March 18, 2020, 03:00:06 PM »
Why use the ignition switch. It has a job and there are better places to hook into.
da prez
wirral_biker
Wirral, ENGLAND
March 18, 2020, 04:32:24 PM »
Bottom left side of fuse on the right of the bike...splice into that one !
I will never learn, on my 4th Valkyrie now !
March 18, 2020, 05:49:13 PM »
There is an accessory plug under the right cover. It's only 5 amp, but you can use it with a relay if you need more power.
Paladin528
March 19, 2020, 10:32:10 AM »
there is a spare connection on the Start relay. you need the correct connector to add a wire it but is is a good place to grab power from if needed.
I needed ACC power to trigger my amplifier when the ignition was switched to ACC. I used the +12V power lead that is meant for the CB from the connector under the right side cover. Worked like a charm
RonW
Newport Beach
March 19, 2020, 11:58:21 AM »
That is so brilliant!!
2000 Valkyrie Tourer
Reply #6 on:
March 19, 2020, 05:48:36 PM »
Quote from: meathead on March 18, 2020, 05:49:13 PM
Is the acc plug on all bikes, I thought it was the IS only? (I've only had an IS)
Reply #7 on:
March 19, 2020, 05:53:19 PM »
Quote from: gordonv on March 19, 2020, 05:48:36 PM
It's on them all.
Reply #8 on:
March 20, 2020, 10:08:28 AM »
Quote from: meathead on March 19, 2020, 05:53:19 PM
It's on them all.
The accessory leads are on all 1500 Valkyries, which is turned on when the ignition is in the "on" position, fed by the 5A accessory fuse. The Interstate has an accessory position for the key, which powers the audio system (and maybe other stuff?) from the 5A audio-meter fuse.
=> InZane XXV
