November 13, 2025, 08:46:06 AM
5a accessory wire
Topic: 5a accessory wire (Read 1007 times)
Whitey
5a accessory wire
March 21, 2020, 12:39:07 PM »
I just picked up a garmin 395lm and wanted to hard wire it!
I noticed it has a 2a fuse in the harness that came with it so I was wondering is the 5a accessory enough power for the GPS? Thanks!
3W-lonerider
Shippensburg Pa
Re: 5a accessory wire
March 21, 2020, 02:02:41 PM »
yes no problem.
Whitey
March 21, 2020, 02:06:44 PM »
Thanks buddy! I was thinking yes but wanted to make sure! I'm not to good with electric stuff! Whatever you call it!
9Ball
March 21, 2020, 03:15:47 PM »
If you want to add other electric accessories, this connection makes a good trigger for your accessory fuse box.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
da prez
Wilmot Wi
March 21, 2020, 04:54:23 PM »
BE SURE the fuse is close to the battery in any installation.
I have seen many electrical fires because the fuse was at the end of the circuit.
da prez
pokrovsky
March 21, 2020, 06:34:28 PM »
I wired my Garvin Zumo 595 to the auxiliary power connection under the right side cover. I found the crimp on compartible pins to make it look totally OEM
)) and not to overload the battery terminals directly
=> InZane XXV
