December 30, 2025, 11:38:43 PM
Losing Fluid from Clutch Reservoir
Topic: Losing Fluid from Clutch Reservoir (Read 1635 times)
Coot
March 22, 2020, 05:53:53 AM »
Good morning. I am slowly losing fluid from my clutch reservoir. it requires topping up every 500 miles, or so. No signs of leaks and no puddles on the garage floor. Thoughts, please.
h13man
Indiana NW Central Flatlands
Re: Losing Fluid from Clutch Reservoir
March 22, 2020, 07:05:04 AM »
Its got to be leaking somewhere. I'd check the slave cylinder area as it a hard place to see. This fluid is very caustic to about everything it touches.
March 22, 2020, 07:08:40 AM »
There is a seal on the push rod in the slave area, that when it leaks, the fluid will get into the engine oil.
h13man
March 22, 2020, 07:21:57 AM »
^^^^^ Cool! Never have looked or been concerned to where that item was located/designed. Thanks! We'll be a watchin' as that chit is bad juju as I mentioned.
Coot
March 22, 2020, 02:44:22 PM »
Thanks, as always, for the helpful info. Coot
Coot
March 24, 2020, 05:43:22 AM »
FYI: I believe that I have traced the problem to the slave cylinder, thanks to your helpful suggestions.
Coot
Reply #6 on:
March 24, 2020, 07:42:09 AM »
Here ya go:
https://www.partzilla.com/catalog/honda/motorcycle/1997/gl1500ct-a-valkyrie-tourer/clutch-cover
Part #14 I believe.
BUT
You should also renew the seal on the slave piston and clean the slave cylinder bore.
Because that is the main problem you are having.
That is where the leak is actually occurring.
=> InZane XXV
