December 30, 2025, 11:37:43 PM *
Author Topic: Procedure for checking vacuum/petcock failure?  (Read 1600 times)
Simmy74
Lapeer Mi
« on: March 22, 2020, 07:41:49 AM »
Rebuilt the valve ~6k ago and now the valve won't function when open or (or on reserve).  Ran nicely through what was in the bowls but they are not being refilled from the (full) tank.
I'm guessing it's the vacuum line, but just wondering if there is a preferred way of diagnosing this one and if vacuum failure elsewhere might cause it even with a good line to the intake?
Thanks guys
Guns don't kill people.   Drivers with cellphones do.
« Reply #1 on: March 22, 2020, 09:24:52 AM »
Thanks guys
The vacuum line is easy to check. If it’s good most likely it’s the petcock diaphragm itself. I’d replace with a quality valve and quit worrying about fuel delivery
Dusty
Mill Bay B.C.
« Reply #2 on: March 22, 2020, 12:31:45 PM »
You can get a short piece of line and hook it up to the vacuum port on the fuel valve. apply some suction to the line and that should open the valve and refill the bowls. If that works you have a vacuum supply  issue and not a petcock issue. Also check that your vent line is not pinched or kinked because that will also show up as no fuel .
Dusty
Jruby38
Oxford Mass.
« Reply #3 on: March 22, 2020, 03:12:38 PM »
Can the OEM POS. Get a Pingle manual petcock. Buy once, cry once.
Simmy74
Lapeer Mi
« Reply #4 on: March 22, 2020, 07:05:06 PM »
Thanks guys
Nothing I'd rather do than work on my bike for the next two weeks anyway
Gondul
VRCC #408
Central Florida
« Reply #5 on: March 23, 2020, 07:19:20 AM »
i second a Pingel, but even with a manual cutoff, there is still enough fuel left in the line to cause hydro-lock; I turn the pingle to 'off' about a mile from the house to minimize the amount of fuel in the line.
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
f-Stop
'98 Standard named Hildr
Driftwood, Texas
« Reply #6 on: March 23, 2020, 08:12:11 AM »
Is this issue something that happens after running for a bit?  If so, it could be the tank vent line.  Check to see if it's clogged or pinched in some way...
...if it's simple fuel flow, maybe check the petcock for clogs or malfunction...
...or maybe the #6 vacuum line is shot...
...or the cover set has gone bad after only 6k miles...
Good luck!
Jruby38
Oxford Mass.
« Reply #7 on: March 23, 2020, 03:33:19 PM »
No way the 1.5 oz of gas in the line can lock up a 1500 cc motor.
« Reply #8 on: March 23, 2020, 05:44:13 PM »
Only needs to go in one cylinder to lock it up. I don't know how much it would take, but I'd guess an ounce and a half would be enough.
tcblack
Moweaqua
« Reply #9 on: March 25, 2020, 10:07:53 AM »
Is there a suggested Model for the Valk?  I really like the look of the OEM valve, but this hydrolock thing has me a bit worried.
http://www.pingelonline.com/prodcat/fuel-valves.asp
Sarcasm is my love language, do you feel loved yet?
- 1998 Valkyrie named Eir.  Eir was the Valkyrie whose name may translate to Peace or Healing.
Gondul
VRCC #408
Central Florida
« Reply #10 on: March 25, 2020, 11:52:26 AM »
If you go to the bottom of the page, there is a drawing showing the different types available...given the position of the petcock, the 1000 series (tank on the left, lower left) will likely be the easier to reach... also keep in mind the reserve is much less than OEM.
http://www.pingelonline.com/Fuel-Valves/designer.asp
John Adams - 1797
« Reply #11 on: March 31, 2020, 09:01:11 AM »
I think you are saying you like look of the OEM switch. That is not the valve. The switch hooks to the valve to operate it. That switch is not used when you install a Pingel.
Simmy74
Lapeer Mi
« Reply #12 on: April 05, 2020, 11:54:20 AM »
Ok,
I got the Pingel and am in the middle of the install.
Here's what I discovered-
Regardless of the valve (it's off at the moment) the tank will only trickle a small stream of fuel out the port.  If the lid is open, she pours like rain.
I'm assuming this means a clogged vent, so I reamed the vent tube with a 12in pipe cleaner but it didn't fix the problem.
Is there a way to get at the OTHER end of the vent path through the top of the lid?  I looked and didn't see any tube or port.
Simmy74
Lapeer Mi
« Reply #13 on: April 05, 2020, 12:24:55 PM »
I'm guessing I "could" modify the lid gasket to not seal, thereby making a permanently vented cap, but I hate those types of solutions to stuff
Lyle Laun
Calgary, Ab
« Reply #14 on: April 07, 2020, 09:57:29 PM »
I’m pretty sure Mark T Swapped his gas cap to a vented one. Here's the notes that I have from That time  “ Vented gas cap from a 1983 Honda Magna 17620-MB1-033”
Check with Mark T for confirmation if you decide to go that route.
Regards
Lyle
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
Gregory Scott 16248
Pittsburgh, PA. Cranberry TWP.
« Reply #15 on: April 08, 2020, 05:13:31 AM »
See what happens with a fuel leak from the petcock. My hydrolocked engine, now repaired. I replace the petcock with a new OEM petcock and added an electric fuel shut off valve and control switch before the T in the fuel line. I don't want to repair this again. I switch off the electric fuel shut off valve when I enter the neighborhood and shut off the OEM petcock which drains the fuel line and some fuel in the carburetor bowels.
Dan-Marc 12 Volt 1/4" Orifice Multi Purpose Shut Off Valve Item# 79-AFC1211412 http://www.dan-marc.com/79-afc1211412.html
« Last Edit: April 08, 2020, 05:41:59 AM by Gregory Scott 16248 » Logged
VRCC#16248
1999 Interstate with Lehman Predator Trike Kit
2008 Goldwing L3 with Motor Trike Kit
2009 Kawasaki Vulcan 900
2021 Can-am F3 Limited Chrome Edition
2019 Forrest River Trailblazer 30' Toy Hauler
