March 26, 2026, 11:24:08 PM *
Author Topic: Tire Pressure Gauge  (Read 783 times)
Shasta
« on: March 24, 2020, 05:45:40 PM »
Hello fellas,
Any recommendations fro a good tire gauge?
is there screw types?  Or do you just hold behind the 45 degree stem while testing?
Thanks, Matt
shadowsoftime
mannsville,ok
« Reply #1 on: March 24, 2020, 05:51:50 PM »
Don't know brand but mine has a round glass cover, needle gage with a pressure release.
« Reply #2 on: March 24, 2020, 05:54:30 PM »
Mine looks almost like this.   I think it's a different brand and goes to a higher pressure.
I've found this type to be more accurate than others I've tried.  Holy cow that's a long URL !
https://www.ebay.com/itm/JACO-Elite-Tire-Pressure-Gauge-60-PSI/221970069095?epid=16029686626&_trkparms=ispr=1&hash=item33ae727667:g:VBoAAOSweN9dbv4O&enc=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&checksum=22197006909517c34f31da504c458d7803bde41ddd65&redirect=mobile
« Last Edit: March 24, 2020, 05:56:02 PM by Valkorado » Logged
da prez
Wilmot Wi
« Reply #3 on: March 24, 2020, 05:55:17 PM »
Electronic. Most parts store.
           da prez
shadowsoftime
mannsville,ok
« Reply #4 on: March 24, 2020, 05:59:15 PM »
That looks like mine but the rubber part on mine is smooth, no gears. Goes to 100 lbs
« Last Edit: March 24, 2020, 06:01:52 PM by shadowsoftime » Logged
« Reply #5 on: March 24, 2020, 06:02:50 PM »
Acutire electronic (or other such) gauges.
LED screen, some are lit when in use (which helps find the hole in poor light), and accurate to a half pound.
https://www.amazon.com/Accutire-MS-4021B-Digital-Pressure-Gauge/dp/B00080QHMM
Some form of electronic gauge can be found at most any auto parts store, as Ross mentioned.
Once you get one new, use it to set a tire pressure, then check that pressure with any other old stick and sweep gauges you may have, and throw the inaccurate ones out.  All but a couple of my old ones went in the trash.
Batteries don't do well in cold, so bring them inside in winter.
« Last Edit: March 24, 2020, 10:58:18 PM by Jess from VA » Logged
Shasta
« Reply #6 on: March 24, 2020, 06:05:11 PM »
Thanks!
« Reply #7 on: March 24, 2020, 06:30:39 PM »
Hello fellas,
Thanks, Matt
Matt, have you switched over to metal tire valves ?
If not, I highly recommend it.
You definitely need to support the OEM style valves when checking the pressure.
I agree with the electronic gauges.  cooldude
« Reply #8 on: March 24, 2020, 06:34:07 PM »
I have this one:
https://pitstopusa.com/i-23898890-longacre-semi-pro-digital-tire-gauge-0-60-psi-2-5.html?ref=category:134512
It's expensive but I wanted high accuracy.
This one is probably all you really need:
https://www.amazon.com/JACO-ElitePro-Digital-Pressure-Gauge/dp/B07JL8YB36/ref=sr_1_6?keywords=high+accuracy+digital+tire+pressure+gauge&qid=1585099420&sr=8-6&swrs=7B619039638F67FDCCE3160E97ED956C
And it's a good bit cheaper.
shadowsoftime
mannsville,ok
« Reply #9 on: March 24, 2020, 06:34:44 PM »
My electronic ones are in the trash at the landfill.
« Reply #10 on: March 24, 2020, 07:06:40 PM »
I got my dial gauge at NAPA... I took three or four out in the parking lot and checked
my tires. They all read the same. Since we're checking pressure in motorcycle tires and
not nuclear containment vessels  Wink I'm satisfied with the one I brought home...
Avanti
Stoughton, Wisconsin
« Reply #11 on: March 24, 2020, 10:23:36 PM »
Buy a small one that you will carry with you and use.
Check it against a few at home gauges to see if it is calibrated correctly.
If it is off just make a note on it as to how far off it is.
