December 30, 2025, 11:36:45 PM
Vacuum Lines
Topic: Vacuum Lines (Read 1198 times)
valktrike
Vacuum Lines
March 26, 2020, 10:44:57 AM »
Good afternoon. I have a 2001 Standard that has a Motor Trike conversion. Last fall, I had a small electrical fire caused by a cheap aftermarket alternator. I was lucky and got the fire out before too much damage was incurred. I have fixed all the damaged wiring but there are some vacuum lines near the battery box that melted and I cannot find anything about them. Does anyone know where these lines come from, where they go, or how they're connected?
da prez
Wilmot Wi
Re: Vacuum Lines
March 26, 2020, 12:23:09 PM »
Sounds like the fuel tank overflow and the drool tube. Try to locate the other ends by size .
da prez
Re: Vacuum Lines
March 26, 2020, 12:43:45 PM »
where are you located?
valktrike
Re: Vacuum Lines
March 26, 2020, 02:21:49 PM »
I'm in NW Arkansas.
valktrike
Re: Vacuum Lines
March 26, 2020, 02:24:11 PM »
Drool tube. I like that! i found both of those. they are intact. These are smaller lines. One has a Tee in it (a little melted, but still a Tee)
Re: Vacuum Lines
March 26, 2020, 03:01:18 PM »
Quote from: valktrike on March 26, 2020, 02:24:11 PM
That would be the fuel tank vent line. When replacing put a tee back in.
9Ball
Re: Vacuum Lines
Reply #6 on:
March 26, 2020, 03:26:35 PM »
If you have access to the Honda service manual then there are diagrams in the front of the manual showing all wiring and tubing routing. These diagrams have helped me a time or two.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
da prez
Wilmot Wi
Re: Vacuum Lines
Reply #7 on:
March 26, 2020, 03:33:33 PM »
BE VERRY CAREFUL. Old 2soon lives just north of you.
da prez
valktrike
Re: Vacuum Lines
Reply #8 on:
March 26, 2020, 04:20:08 PM »
This may be a stupid question but does a vacuum line come off of the tee? If so, where does that line go?
Re: Vacuum Lines
Reply #9 on:
March 26, 2020, 04:56:45 PM »
Quote from: valktrike on March 26, 2020, 04:20:08 PM
It's the vent line from the fuel tank, to the T, then to the ground. The other end of the T is left open. The hose is the size of the vacuum line.
valktrike
Re: Vacuum Lines
Reply #10 on:
March 26, 2020, 05:46:21 PM »
Thanks everyone! I do believe I've got it ready to put back together.
=> InZane XXV
