February 13, 2026, 05:06:36 AM *
Author Topic: Saddlebag Lock?  (Read 1611 times)
PharmBoy
Lawton, Ok
« on: December 12, 2009, 06:07:49 AM »
Does anyone here know how to remove the lock mechanism from the latch on the saddlebag or does it take a special "locksmith" tool to remove the body of the lock from the latch part?  The key & tumblers are out, but I can't find the secret to removing the body that holds the tumblers....Thanks....JTL   uglystupid2
« Last Edit: December 12, 2009, 06:10:12 AM by PharmBoy » Logged
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
roboto65
Conroe,TX
« Reply #1 on: December 12, 2009, 06:12:34 AM »
On my Interstate there are 3 8mm nuts holding the unit on in the bag..
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
PharmBoy
Lawton, Ok
« Reply #2 on: December 12, 2009, 06:15:18 AM »
The latch and lock are off the bag and the key and tumblers are out of the body of the lock.  I just do not know how to remove the body of the lock from the latch...JTL
99 Interstate
97 Bumble Bee
97 Red & White
PharmBoy
Lawton, Ok
« Reply #3 on: December 12, 2009, 02:56:47 PM »
If anyone ever needs to know how to remove that lock housing, I can now tell you...JTL   Grin
99 Interstate
97 Bumble Bee
97 Red & White
DeShazo
« Reply #4 on: May 09, 2017, 07:45:23 PM »
Hey, I was digging through the archives hoping someone had done this before. So Pharmbou, how does that damn thing come out? I tried for about 30 minutes with no luck.
« Reply #5 on: May 10, 2017, 04:40:10 AM »
I'm not sure what you're after, if painting or something, I guess the whole thing
has to come out.
I got a whole new key set and replaced all the locks on my bike. I thought getting
the whole latch off the saddlebags was going to be hard, it is sealed (to keep
out water I guess) with goo. I just changed the guts to the lock and was happy,
I guess you're saying you already have the guts to the lock out...
Bagger John - #3785
« Reply #6 on: May 10, 2017, 06:15:25 AM »
When re-keying, you just need to change the barrel pins UNLESS you're changing key types ("A" to "B", or vice versa). Then you change the barrel. No need to change the lock bodies.
A good source of parts are the lock assemblies found on GL1100/1200 'Wings. I regularly find these at swap meets for a buck or two apiece.
