November 13, 2025, 06:43:52 AM *
Author Topic: How to select a good gear oil based on VI index.  (Read 3504 times)
« on: March 30, 2020, 08:41:52 AM »
https://www.machinerylubrication.com/Read/28956/lubricant-viscosity-index
High or Low Viscosity Index needed?
If conditions are not constant (variable loads, variable speeds, variable ambient temperatures, etc.), then there is a need for not only the optimum viscosity but also a high viscosity index to stabilize the optimum viscosity. The more variable the conditions, the greater the need for high VI oils.
Also, keep in mind that for a great many machines there has been no past experimental or theoretical effort to identify the optimum viscosity. Viscosity selection is more of a wild guess. This too calls for a high VI lubricant.
A lubricant may merit having a high VI for one or more of the following reasons:
    The optimum viscosity is not known
    Varying loads and speeds exist
    Varying ambient temperatures exist
    To boost energy efficiency
    To boost oil service life (lower average temperature)
    To boost machine service life (fewer repairs and downtime)
Cheaper, lower VI lubricants may make sense if:
    Speeds and loads are constant
    Temperature is constant (constant ambient temperature or a heat exchanger is in use)
    The optimum viscosity at the operating temperature is known and is consistently achieved
For 75w90 oils;
checking mobil 1 gear oil, it actually has a low VI and according to the above is not good for valkyrie final drives which needs a high VI.
Mobil 1 syn gear oil has a VI of 146.
https://www.mobil.com/en/lubricants/for-personal-vehicles/our-products/products/mobil-1-syn-gear-lube-ls-75w-90/
checking some others, Valvoline syn has a VI of 150.
https://sharena21.springcm.com/Public/Document/18452/3e467451-fe75-e711-9c10-ac162d889bd3/cf662252-0bbd-e711-9c12-ac162d889bd1
Peak Auto syn has VI of 162  and has the lowest cost.
https://peakauto.com/wp-content/uploads/2017/01/PEAK_Gear_Lubricant_Oil_75W90_75W-140_Oil_Spec_Sheet_2016.pdf
Amsoil severe gear has VI of 166.
https://amsoilcontent.com/ams/lit/databulletins/g2043.pdf
Amsoil long life has VI of  143.
https://amsoilcontent.com/ams/lit/databulletins/g2042.pdf
This is what I've been using for years in my vehicles.  I'll be changing over to Peak from now on.
interesting that the article considers a Low VI as cheap oil.
WintrSol
Florissant, MO
« Reply #1 on: March 30, 2020, 09:06:45 AM »
Just one more reason I went with Amsoil.
Ken aka Oil Burner
Mendon, MA
« Reply #2 on: March 30, 2020, 03:33:41 PM »
Amsoil is definitely good stuff.  cooldude
« Reply #3 on: April 24, 2020, 11:18:53 AM »
found a great product that is a synthetic even though they are not calling it that.
I've will be using this which is half the cost instead of the Peak synthetic oil or the Amsoil which I have used
Valvoline high performance gear oil 75w90
VI 166
40cst  99
100cst 15.9
pour point C  -39 degrees
https://sharena21.springcm.com/Public/Document/18452/54447451-fe75-e711-9c10-ac162d889bd3/76f88e7f-fbbc-e711-9c12-ac162d889bd1
Compare to Amsoil  severe gear 75w90
VI 166
40cst  102
100cst 15.9
pour point C  -45degrees
