December 31, 2025, 01:21:18 AM *
Author Topic: Cylinder reinstall  (Read 1238 times)
twisted
VANCOUVER ISLAND
« on: April 04, 2020, 03:41:59 PM »
Hi... I had to remove the 2,4,6 bank of cylinders to replace a bent connecting rod... I was wondering if anyone had a suggestion on how to reinstall the cylinders without the use of the fancy honda tools for the rings?
thanks
« Reply #1 on: April 04, 2020, 04:36:37 PM »
If you're talking about a ring compressor, when I split the case on the GL1200 I used large hose clamps as compressors to assemble the halves. To remove them you need to leave enough finger room to get in there and unscrew them with a screwdriver and open them up to remove. I'm not familiar how wide spread the rings are top to bottom on a Valkyrie piston, but the hose clamps I used were just wide enought to cover all the rings on the 1200 pistons. Worth a look at least.
ridingron
Orlando
« Reply #2 on: April 04, 2020, 10:08:11 PM »
If you have a hose clamp that idea will work. I haven't bought one for decades but how much are they. 25?
« Reply #3 on: April 05, 2020, 08:15:46 PM »
Hose clamps? No, should be less than $5 ea for those big enough to go around a piston. And if they're not wide enough to cover all the rings, cover just the top ones to get them in the cylinder, then loosen the hose clamp to move it down and cover the bottom ring(s). In years past on automotive engines I've cut a beer can or coke can open and slipped the hose clamp down over it. Worked as good as a commercial compressor and a lot less $$, plus I got to drink the contents first.  Wink
twisted
VANCOUVER ISLAND
« Reply #4 on: April 08, 2020, 08:15:49 PM »
Thanks guys.... I just thought that the hose clamps might scratch the piston.... I was trying some thin aluminium sheet with zap straps... but will try... Cheers
Gregory Scott 16248
Pittsburgh, PA. Cranberry TWP.
« Reply #5 on: April 08, 2020, 08:43:11 PM »
You can cut an aluminum soda pop / beer can to the width that you need and then use the hose clamps around the aluminum can to compress the rings.
VRCC#16248
1999 Interstate with Lehman Predator Trike Kit
2008 Goldwing L3 with Motor Trike Kit
2009 Kawasaki Vulcan 900
2021 Can-am F3 Limited Chrome Edition
2019 Forrest River Trailblazer 30' Toy Hauler
« Reply #6 on: April 09, 2020, 12:04:01 PM »
Uh...Greg...that's what I said, except I used a beer can which has the same properties in the container, not the contents.  Wink
And no, the hose clamps won't scratch the pistons. The inside surface is smooth, or at least should be.
