March 26, 2026, 09:20:22 PM *
Author Topic: Plug and play L E Ds  (Read 422 times)
« on: April 05, 2020, 01:08:42 PM »
    Found some from wally wurld that Work. Started out over the kitchen sink with the 24" dual tube fixture there. And those worked so danged good did the R & R on both 48" fixtures in the shop. WOW and Dang!  2funny The difference Is Very noticeable. Guy I talked too at w w told me if the ends match they should work. Mine did. These specs are for the 48" but I reckon the 24" specs are very similar. 32 watt equivalent. 1825 lumens. 4100 K which is listed on the box as cool white. Life expectancy 50000 hours. That's a bit over 2083 days at 24 hrs a day. I'm thinking about mounting another 48" fixture across from my work bench. Should be well lighted then except under the cage. A new 48" fixture is right at 20 bucks. 2   48" tubes just under 9 bucks. Naturally prices is before taxes!  2funny And there IS indeed a savings cuz I've already seen the savings on my monthly tricity bill. Anyway I'm am happy with the lighting modification I under took. Also took the time to clean all the old fixtures. BUT that's a story fer another day!  Grin RIDE SAFE.
