December 30, 2025, 11:37:40 PM
Filter box after de-smog
Topic: Filter box after de-smog (Read 1091 times)
dpcarson
Lillington, NC
April 06, 2020, 10:43:53 AM »
OK, Verification, after de-smog I should have one hose from filter box to breather, one nipple plugged completely, and one with a hose simply to drain out. Is that correct? Or, does that drain tube need to be connected back in with the breather also?
O-B-1
Vancouver, WA
Re: Filter box after de-smog
April 06, 2020, 11:46:39 AM »
Drain tube should go down to the bottom of the bike with a plug in it so you can drain condensation from the box.
The big nipple where the PAIR system hooked into needs to be plugged securely.
You should be able to find an article on here explaining what needs to be done. I can't remember where the other line goes.
Hope that helps.
David W. Mitchell
1999 Honda Valkyrie GL1500C
dpcarson
Lillington, NC
April 06, 2020, 12:40:10 PM »
Thanks. That is what I thought. It had been a while since I de-smogged Lazarus, and wanted to make sure I was not missing anything.
April 06, 2020, 05:59:41 PM »
http://www.valkyrieriders.com/shoptalk/desmog.htm
=> InZane XXV
