December 30, 2025, 11:37:18 PM *
Author Topic: Fuel issue solved, unexpected culprit  (Read 1219 times)
Simmy74
Lapeer Mi
« on: April 06, 2020, 04:49:19 PM »
What I initially thought was a faulty PC led me to do the Pingel swap.  In the process of replacing the valve I discovered that the stock filter "sock" was restricting flow from the tank.  The stock was not clogged, but contains a rubber grommet inside at the top of the PC tube, and the grommet had dislodged, rotated, and became a restriction at the mouth of the tube
Guns don't kill people.   Drivers with cellphones do.
BigSherm
« Reply #1 on: April 06, 2020, 09:22:29 PM »
Sweet!
Thanks for the tip!
Scott
