January 28, 2026, 05:09:44 AM
exhaust stacks
Topic: exhaust stacks (Read 7662 times)
CRUZIN
Alberta
exhaust stacks
March 06, 2009, 08:11:47 PM »
I want to install some stacks on my tourer, what size of stack will work? and will a turn out stack drag when cornering? I hear that they fit tight over the muffler any install tricks and pictures would be a great help. Thanks
Re: exhaust stacks
March 06, 2009, 08:20:49 PM »
Go to the top of the page where it says shop talk. Click on shoptalk and then you will see a section on pipes there. Should answer a lot of questions.
Udo
Germany, Krefeld
Re: exhaust stacks
March 07, 2009, 03:41:49 AM »
I used the stacks from
www.airflo.com
(Valkyrie section), 4" inner diameter. To mount them, i used a ratchet strap, and tapped the end of the stack gentle with a piece of wood. Yup, they are tight. A soft mallet will also work.
Six Packer
Re: exhaust stacks
March 07, 2009, 03:47:34 AM »
I used the Air-Flo 4-inch stacks. They come in different lengths and are of good chrome quality. Vasoline works well to help with the slide on procedure--like always.
