December 31, 2025, 01:21:20 AM *
Author Topic: Im confused carb rebuild  (Read 1149 times)
jackt
This is one of my babies
Central Kansas
« on: April 10, 2020, 01:04:37 PM »
I finally gave up on sea foam Lucas injector cleaner and 2 or 3 others to clean carbs.
I have taken carbs out and starting to clean and getting ready to order parts needed.
I have seen many on this site recommend the float valves at amazon BUT when I follow the link they post.
amazon tells me there not right for my Valkryie. Even Bons post this link for
K&L Supply K&L Float Needle for 93-95 Honda CBR900RR .
https://www.amazon.com/Supply-Float-Needle-6pk-18-8955/dp/B001KOD732/ref=au_as_r?_encoding=UTF8&Make=Honda|59&Model=GL1500CF%20Valkyrie%20Interstate|17894&Year=1999|1999&ie=UTF8&n=15684181&s=automotive&vehicleId=7&vehicleType=motorcycle
Will they work for my bike? and are they any good.
Jack
2006 Shadow
1999 Standard (fast black)
1997 Bumblebee
2005 Gold Wing trike
« Reply #1 on: April 10, 2020, 01:14:34 PM »
Why not order a complete kit from All Balls, p/n 26-1629. Has all the gaskets, bowl screws, all new jets, new float valves, all o-rings, new idle mixture screws...everything needed for overhaul except your time and solvent. I just ordered off Ebay for $96 plus tax, came to $101 in Wisconsin. It's the same kits used by Attic Rat on his rebuild projects. That p/n will cover all six carbs in one kit.  cooldude
Ramie
2001 I/S St. Michael MN
« Reply #2 on: April 11, 2020, 06:19:56 PM »
All I can tell you is those are the ones I used when I redid the carb bank on a standard I used to own and they worked fine.
