December 31, 2025, 03:16:54 AM *
Author Topic: Have carbs off more questions  (Read 1066 times)
jackt
This is one of my babies
Central Kansas
« on: April 13, 2020, 05:29:52 AM »
It’s cold in Kansas again. It was 90 degrees in Kansas Saturday yesterday and today 20s. Saturday evening I finally have the carbs off Valkryie, and dinner was ready.
Sunday,  very cold and no heat in MC building but I went out for a little to pull them pretty much apart and put in containers so I can put back together (pray - pray).  PS I do not have air cut and enricher removed.
I noticed some of the little brass ports/air passages on air funnel side of carbs looked plugged, all I had for air was pc cleaner type can of air so I blew in it and it pushed out crud and fuel.
When I blew unto one it made the enricher valves kind of flutter the other didn’t seem to do anything.
My question is does anyone know what each is function of all the ports on funnel side and piston vacuum side. I think it would help to know what does plug up so we can be sure these are clean.
Jack
2006 Shadow
1999 Standard (fast black)
1997 Bumblebee
2005 Gold Wing trike
« Reply #1 on: April 13, 2020, 09:12:19 AM »
One opening is the float bowl vent.
Another one is the air intake for the cut off valve.
The other is a vent for the low speed circuit.
