December 31, 2025, 01:21:14 AM
Timing Belts Change
Topic: Timing Belts Change (Read 1083 times)
Algonquin Highlands, Ontario Canada
Timing Belts Change
April 14, 2020, 12:06:26 PM »
Hi all,
Just changed my timing belts. Wondering if it is alright to start the bike without the cover on? Just wanted to see it working and make sure all is good after running it for a bit.
Re: Timing Belts Change
April 14, 2020, 12:25:35 PM »
Yes it will be fine
Just make darn sure all the markers line up. 1/2 mark and the “up” s all lines up. Turn it by the crank bolt and check it at least twice!!!
Last Edit: April 14, 2020, 12:45:17 PM by Chrisj CMA
April 14, 2020, 03:56:28 PM »
Quote from: Chrisj CMA on April 14, 2020, 12:25:35 PM
Yes it will be fine
Turned it by hand several times and everything lines up every time.
Thanks again
=> InZane XXV
